Fabia radio fuses?
Hi,
I have a Fabia 1.4 classic (2001). The radio headunit's been replaced and I've swapped over the Iginition/Battery feeds and fitted an aftermarket pre-amp. However I somehow managed to blow the fuses.
Ive replaced the radio fuse (pos 45) in the fuse box and the fuse on the headunit is OK. However it still refuses to powerup. The ignition feed does have any power when the ignition key is turned on.
Doing some searching on the internet, it transpires that there may be two fuses for the radio in the fuse box, does any one know the fuse number for the other fuse please?
Danish.:o
I have managed to get this fixed thanks to Jim at SJB Autotech in Basingstoke.
The radio fuse positions are as follows;
Pos 45 Battery feed Large 20A
Pos 10 Ignition feed Small 5A
