Playing MP3's
Hi,
I have a multi disc in the boot and if I insert a MP3 disc into it the desplay says that it is a CD ROM but does not play.
Is there anyway to get the multi disk to play MP3's?:confused:
nope, it only works on the Audience or Stream MP3 head units, not in the multichanger
Correct. Which is a pain in the **** and makes the changer completely redundant if oyu have a stream MP3. Hmm, what else can i plug into that lead instead? :confused:
Chris
Chris
You can get a proper iPod connection lead that will replace the autochanger from the back of the head unit, but if you have the jumbo box with headphone socket in it that sort of makes that redundant to.
or add your own aux in lead, many have done that too,including me.
Thanks Guys,
Yes I do have the jumbo box with headphone socket so I will need to use that.
i found that the volume is very very low if i plug my creative zen mp3 player through the aux socket in the jumbo box. any way to increase the default volume for the aux socket on the headunit?
Yes, by reading the manual.
There are three settings for aux in volume, all control through the head unit audio settings menu.
Chris
Chris
phatnoise system plugs straight into the CD Changer lead, 20GB MP3 system.
Cool. i'll crank up another explorer window and check that out.
Chris
Another :thumbup: here for the Phatbox. It even talks to you.
Does it tell you its discontinued? :thumbdwn:
Chris
