Squeaky Clutch
Just noticed it the other day.
After I've been driving for a while, clutch groans when taking off in first gear if she doesn't get enough revs. (Kinda like the noise a bike brake makes when you pull it in the rain) :P
She's just hit 10,500 miles and only just started squeaking.... I'm not detecting any slippage though and she still bites cleanly in the rest of the gears - guess I'm just worried that the clutch may be on its way out. :o
A few of you guys are driving round in seriously tuned cars... and most of you are still running on original clutches - how do you get away without groans and squeaks? :confused:
Has anybody else had this?
Sounds like the release bearing.
Is it expensive to fix/replace? :confused:
Not sure; you'll have to check with a dealer. But as with most things, the bearing itself is not expensive (£20ish) but replacing it is what incurs the cost as the clutch itself will almost certainly have to be dismantled.
*Groan* :(
Is it the Octavia with the problem? Won't it be under warranty?
Yeah it still is... it hasn't been a problem today.
I'll keep an eye on it... cheers :thumbup:
