Denison Gateway 100 + CD Retention Module
Guys
Just had the Gateway 100 + CD Retention Module fitted to the Octavia Stream Head Unit
However I'm sure I must be doing something wrong [ or is it just complicated to use :) ]
When I connect the IPOD it plays with no problems, however I do not seem to be able to select individual playlists. It just plays all tracks one by one.
Selecting the original CD pplayer is a pain in the *** as well.... select disc 6, track 9 then hold the fast foward button for 2 secs :eek:
Can someone give me any tips on using it at all ?
Guys
I'm sure I read somewhere that you need to use the CD buttons to chose between playlists. Numbers 1 to 6 are the first 6 playlists, or similar.
Does it work well so far?
Hi Bubba
Long time no speak.... I tried and prevailed and at the end of the day had it taken out.... It's going back to denison with a comment that its crap !
It doesn't do what it is supposed to do i.e. play playlists. It will only play all tracks randomly...
When it was plugged in there was a whistling noise through the speaker [ feint, but there none the less ], as if it was a suppression issue.
It caused a loud buzzing through the aux ports when on !
And to top it off, the radio packed in !
Getting back to the original Cd player was a nightmare, disc 6, track 9 hold the ffwd button for 2-3 seconds but you couldn't go back to the IPOD without disconnecting it then plugging it back in
God what a waste of money !
RANT OVER.... :thumbdwn:
