Hows this Configuration
Hows this for an ice on an Indian Skoda Octavia I RS( 1.8 T , 150 bhp )
Stock HU
Stock Front and Rear door comp./speakers
AMPLIFIERS
JBL GTO 75.4 ( For components )
# 104 watts RMS x 4 channel at 4 ohms
# 284 watts RMS x 2 channel at 4 ohms
# 3 channel mode: 2 x 104W RMS + 284W RMS for sub
# Ratings at 14.4V supply
# Variable cross-over. Variable Bass Boost.
# Speaker Level Input
# Overload protection
# Dimensions (H x W x D): 2-3/8" x 15-1/8" x 12-5/16"
JBL GTO 601.1 (For Sub)
* 424 watts RMS x 1 channel at 4 ohms and = 1% THD
* 580 watts RMS x 1 channel at 2 ohms, 14.4V supply
* Variable cross-over. Variable Bass Boost.
* Frequency Response (–3dB): 10Hz - 302Hz
* Overload protection
* Maximum Input Signal: 5.3V
* Maximum Sensitivity: 210mV
* Output Regulation: .21dB at 4 ohms
* Dimensions (W x H X D)
* Main Unit: 15-1/8" x 12-15/16" x 2-3/8"
SUB :GROUND ZERO
GZRW 12 XD-AL
30 cm 500 watts, cast basket, 2 inch 2 x 4ohm, Alucone, woven in leads, Xmax 18mm, SPL 91,4dB Rs. 11,990
or
GZRW 12 XS-AL
30 cm 500 watts, cast basket, 2 inch 1 x 4ohm, Alucone, woven in leads, Xmax 18mm, SPL 91,4dB Rs. 11,990
( The only difference is the 2 inch 1 x 4 ohm or 2 inch 2 x 4 ohm)
COMPONENTS : ILLUSION ( Rear)
EL 5.1
5.25", 2-way component speaker system 60 watts RMS / 300 watts peak
or
EL 6.1
6.5", 2-way component speaker system 70 watts RMS / 350 watts peak
I.e. around 36000 + wiring and labour charges ( Total estimate 45000 on the higher side) which would be around 1000-1100 USD
