Squeeky Fabia Noise when you turn right a wee solution
Hi all,
Our Fabia has a nnoying squeek and has done so for the last month or so, the funny thing is that it only seems to happen at night when the tempertures drop when you turn right at low speed.
After some head scratching I had a wee look under the car and got out my wd40 and sprayed the steering system which connects to the wheel hub, early indications show that at first the spraying of wd40 did not work but letting it work over a few miles the car has stopped squeeking as much as it did.
If you have the same problem then this wee guide might help.
Step 1: Engage the steering on full lock so you can get behind the wheel.
Step two
Where I'm pointing is where you should spray your wd40 or maintience oil
Step 3
Spray the following parts
A better pic
It seems to be working for me so far but I will keep you updated on this, but going to mention this to Skoda when I get this serviced.
Davy
