Everything posted by Gerrycan
Octavia VRS TFSI Flat Sport 3500-4500 rpm
Doesn't that engine have a dual injection system, direct and port injection? I'm happy to be corrected but I thought the direct injection operates during low revs and idle and the port injection contributes during larger throttle and higher revs. Maybe the port injection has got a bit blocked through lack of use?
Citigo Electric
That is really encouraging. All other things being equal EV energy consumption is directly related to speed. However it sounds like the your inadvertent drafting of other vehicles at 50-55 mph would have significantly reduced your aero drag and energy consumption, increasing your real range. In the early days of the Tesla S, a Scandinavian couple managed to near double the official range on a charge but I think their average speed was something like 18kph. I think your expectation of reduced winter range is realistic with reduced battery efficiency and cabin heating. A warm garage for your baby could make a bit of difference though . Your short EV run to the shops will still monster any ICE vehicle in any conditions though as their consumption is always at its worst after first start.
New personal best - 1.5Tsi 83.3mpg / 153miles
I could not match the 83 mpg figure with my 1.4tsi manual, in the very best of local Aus conditions and no a/c on I'd still be 10 mpg adrift. If I matched the average speed I'd probably be close to 15 mpg adrift. No hypermiling or dangerously close drafting (our interstate trucks do continuous 100 kph speeds and you have to allow about a safe 3 second gap or you may end up running into a 'roo in the middle of the road the truck had the ground clearance to miss) I have driven in the UK on moving busy motorways and A-roads in similar conditions described by the OP and together with the benefits of Active Cylinder Deactivation I can understand how the remarkable displayed consumption could be achieved (even allowing for a possible slightly optimistic reading). The traffic really is nose to tail there , I had to adjust because every time I left my 'safe' gap another vehicle felt the need to dive into it. I thought the loan Fabia manual 1.0tsi I drove just over a year ago could be capable of 90+mpg in optimal warm conditions (flat road and not exceeding 65kph). I'd turned off the a/c in 40+ deg C temps to prove it once but after a bit I was saying "bu##er this for a game of soldiers" and turned it back on. That 3 cylinder engine is really economical but not available in an Octavia here.
@BBDom, I am curious whether your manual 1.5tsi has had the software fix applied to fix the 'kangarooing' since others seem to think it worsens consumption?
Reliability 1.4 TSi, 140 ps
I would consider the lower mileage and manual transmission a wise choice. Enjoy the new car and your camping trip.
@Rogi, is the model you are looking at a manual transmission or equipped with the DSG auto? If the DSG then perhaps it might be prudent to ask for responses from high mileage DSG users.
Yes, that initial raspy sound, well I think it sounds like Darth Vadar breathing lol. On the occasions when it does not happen the average consumption to one kilometre is significantly better than usual. I think your theory is spot on.
I have a 1.4tsi which is about 7 years old but relatively low 'mileage' at 66,000 km. The only issue I have had was a water pump failure and replacement. Common with the VW diesels but relatively rare for this petrol engine. When the pump was replaced it involved some engine dismantling and they reported some carbon sludge. Not surprising since we do so many local short journeys which does not give the engine a chance to warm up. The questions I would be asking are: Regular servicing Type of driving for the 100k mile distance ie stop/start taxi work or regular longer distances. with a preference for the latter. The type of driving will have an effect on the potential internal carbon build up problem. Cam belt replacement is another potential issue for this age/distance as well. As far as I know there have not been any actual belt failures reported in this forum though. I think the engine itself is very good, very smooth, potentially very economical depending on how you drive, low rev torque is outstanding with relatively low lag. While it will happily rev smoothly to the redline, that is not where it does its best work as the torque curve falls off sharply after 4k revs, that is why it only produces 103kw/140bhp max power but very respectable torque of 250Nm for 1500-4000 rev range. Mine uses little to no oil between annual services. I have one small issue with mine from new and that is after the first start of the day the engine is often very jerky in first gear for the 50 metre drive to the road. Once on the road and able to rev out then there is no problem. The strange thing is that it does not always happen and I cannot find a factor that could explain it. Doesn't matter if the first start temperature is near zero or 40+ degrees centigrade (Adelaide, Australia).
Hatchback vs Estate
Combi/estate or liftback/sedan? Is your mk4 noticeably bigger inside than the equivalent mk3?
Hatchback vs Estate
@budster, I know you can do the front wheel removal and vertical storage thing with 3 bikes in a Honda Jazz so it is all to do with storage shape not just total size. I am mulling over getting a Fabia estate and I have to investigate the option of doing the same with that.
Karoq "wood" trim
None really. I just find it a bit incredible that companies like RR and Bentley maintain specific spare trim stock for decades old vehicles. Maybe the OP can achieve his required aesthetic with a real wood veneer?
Hatchback vs Estate
No I can cheat a bit by only having to remove the front wheel and the quick release seat tube. The wife's bike is a small conventional parallel frame and my bigger bike has a sloping top tube as does the hardtail 26" mountain bike. It is tight so I imagine bigger frames would need both wheels removed and that is a bit of a faff. I hate attaching bikes outside a car.
Karoq "wood" trim
I'd go for fake 'carbon fibre' trim rather than fake 'wood' because it will be so much lighter 🤣 My brother-in-law needed some replacement real wood veneer for his older Rolls Royce. No problem as RR keep a few sheets in stock for every individual vehicle they have made so you get an perfect match. He was also surprised how reasonably priced it was.
Hatchback vs Estate
The mk4 sedan is very aerodynamic and if you don't need the minimal extra load space of the estate (and the couple of points worse drag factor) then probably the preferred option I value my mk3 estate because I can put three adult road bikes inside vertically (wheels removed) and carry three people. This would not be possible in the sedan. The aerodynamic penalty for the mk3 estate is minimal (cd 0.30 sedan, 0.31 estate).
Which engine
This question has cropped up before and the general consensus from those who had experience of both was that the 1.2tsi was probably the smoother and slightly more tractable of the two, very little difference in performance but the 1.0tsi was more economical. Like ShyVRS245 I had a Fabia 1.0 tsi courtesy car for a week and was very impressed by the excellent consumption and reasonable performance (my loaned version was the lower powered 5 speed manual). Kicking myself a bit that I did not buy a new Fabia manual before they dropped manuals from the Australian market
98 octane in Citigo
I tend to agree with the sensor issue theory although I remember carbon build up could cause some pinking in old cars.
Beru vs Ngk vs Bosch
Did not change them myself, I just had them changed at the major service for my 1.4tis at about 50k km and 5 years. I did ask for the old spark plugs to be kept so I could examine wear and they did. Quite honestly the plugs were showing hardly any wear, I think they could have done another 20k+ km with no problem at all, but it was a relatively minor cost although I did not notice any difference in performance. This is not a high performance engine so any genuine spark plug you mentioned will do. As an aside, a few years ago I retrieved an old Toyota Echo from from my daughter who was issued a company car (Golf GTi) and the echo had missed a 'few' services so I undertook a major service myself. The standard spark plugs were incredibly worn and about 3x the recommended space. I was somewhat disappointed there was no subsequent noticeable change in performance or economy. In short if your car is going ok at the moment then do not expect too much when you change the plugs.
3 Adults in the back?
It is a while since I last tried to adjust the centre headrest but I remember concluding at the time that ski portal would severely restrict the length of the headrest legs, compared to the normal rear seats. Three adults in the back is practical for short trips but I would not recommend it for any real distance purely because of the centre headrest. In terms of seat width then @Alex-W is right of course in that comfort for three it is relative to their combined "width" but the Octavia/Golf does sacrifice a fair bit of available passenger width for side impact safety. Note the distance from the seat edge to beyond the sill when either front or rear door is open. I'm reminded of that each time I watch elderly (infirm) relatives struggle to access or leave the car.
AMD's 2 litre 304bhp 162mph Fabia Monte Carlo TDi *6 speed conversion*
Spent the evening reading this from page 1 and thoroughly enjoyed it, although I had to skip a few videos but not the final Darkside post. It will be very interesting to see how the extra power and torque translates to lap and acceleration times. The build has come a long way and I love your enthusiasm for the car.
1.2 TSI Monte Carlo
Had a Fabia 1.0tsi manual as a loan car for a week and was very impressed with the overall package (drive, performance, ride, packaging, and especially the excellent fuel economy). Predictably most here are complimentary, so you should arrange for a test drive to make your own impressions. Be a good idea if you can take your dad along as well so he try out how easily he can get in and out. My elderly mother-in-law had fewer problems accessing the Fabia than our Octavia, but everyone is different. Cars I think are relatively spacious tend to shrink when I give substantially bigger friends a lift.
Is a Racingline map worth the extra money?
We will have to agree to to differ on the ecology BS. We may not suffer from the consequences of our actions but I do worry for our kids and their descendants.
Hi @themanwithnoaim, we're doing well but I gave up on Fuelly a year so ago when my figures got too compromised by others unrecorded fueling. I only get around 8L/100 these days with my really short journeys but my wife has discovered that she could get near 5L/100 on her longer journeys in light lockdown traffic and is quite enthusiastic. I knew there was an eco-warrior deep inside you. I'm just so proud of you 😂
How can a person called Alex misspell Axle?
1.4 TSI timing belt and water pump change
Was that the Hillcrest site doing the work? I must admit it is not really a convenient location for me and I look forward to their proposed move to West Terrace. A month is a long time to sort it out, so I guess the lockdown must have affected their sourcing of spares and fitting? I hope it was covered by warranty?
Multilink rear suspension
Thanks, my bad. The Australian market did not get the 1.8tsi for the mk3, or L&K models.
