Jayson
Members-
Posts
51 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by Jayson
My friend said it ain't worth checking my pump as it's not the clutch type so shouldn't be loose ?
What if it's the control module how much are these to buy and where are they fitted ?
Hi could you possibly show me a picture of this please ?
Hi all recently had my air-con re gassed but still it's not working the man at the garage said it could be the pump or a control module and said he can't tell so contact skoda.They want £80 just to diagnose the fault was wondering if there is any other way to find what's wrong ?
Hi it's only recently had a new filter and oil change .
Hi all I've recently noticed that when the car changes down from 3rd to 2nd there is a bit of a clunk noise it doesn't do it all the time only now and then.Is it normal or is there a fault ?
Hi all does anyone know how to remove the speed and rev counter display from the dash as there is a noise i need to try and find.
Hi All My passenger front door handle is wobbly and from unlocking the car the handle has to be pulled twice to get the door open.Once this has been done it opens normally just plays up after unlocking but it's still loose.What could be wrong with it ?
Are the holes where the mats fix down hidden as i can't see them in my car ?
Hi are these the correct ones for me as i can't see any clips in my car to hold down the mats ? Maybe there are sets that don't have clips ?
There don't seem to be any clips on my car to hold mats down.
Hi all does anyone know where i can get some half decent car mats for my 1.9 2005 elegance auto estate ?
Found video on YouTube now so should be ok.
Hi all when i put the fan up high and on screen mode there is a rattling noise near the screen it sounds like something is either loose or blowing around in there.Is there a way to remove the black metal mesh to maybe see what it is ? I took the middle dash vents out but can't see from there.
Hi all does anyone know how to remove the door panel as i need to fix a lock ?
Brake pad wear warning light ?
Jayson replied to Jayson's topic in Skoda Octavia Mk II (2004 - 2013)
The connector was broken can't fix it so joined the wires together now no light haha . -
Dash storage and vent panel removal ?
It looks like one complete panel on mine ? The only bit that removes from the storage part is a rubber insert ( the top panel with hazard switch ) -
Hi all how do you remove the dash panel that has the air vents and storage compartment ?
Hi all is there a way to deactivate the single door opening mode ? I'd like to be able to do just one press to open all doors.
Why do they only have it at the front then ? And is it only one side ? -
Hi all i recently had the brake pad wear warning light turn on looking at the back pads I thought it was because of them.I changed the back pads and noticed there is no sensors so still the light is on.The front pads look fine but is there sensors on them ?
Hi all how do you change the oil and gearbox filter and how long does it take ??
Hi does anyone know what tool i can buy to wind in the brake pistons is it left hand or right hand thread as i see them on ebay but wasn't sure.
Hi roughly how much is a new pair of gas struts for the boot ?
I just use a blow lamp soon defrosts the windows
