voxmagna
Everything posted by voxmagna
  1. OK thanks. It's not throttle position. RPM smooth and holds, drives like it did before. Injector 4 came out covered in black gunge, the O ring seal had disintegrated. 1&3 were oily but not as bad as 4. I've not leak tested them yet. I'm assuming whilst these piezo injectors aren't serviceable, the O ring (s) can be replaced? Although they look bolted together like others I've seen, if I confirm definite leak past I might have a go at tearing it down. I've destroyed a clamp plate now (a tenner each) but it's still stuck. I suspect the O ring seal has gone and carbon is locking it in? I can get a 29mm open end spanner on the top nut but you can only turn it clockwise tighter and since its not a nut with much width metal, I wouldn't put a lot of force on it. The best way to turn the injector a couple of degrees at a time is to hit the side near the union with a steel bar and hammer. It's virtually impossibe to get the upwards force, even with a slide hammer. I'm tempted to make a fitting, attach it to a lifting beam and lift the whole damn car up on then wallop the side with the bar and hammer.
  2. There is no accessible hex part on these common rail injectors. There is, but the connector is fixed over the top as part of the return flow. Correction whilst replying: There is a hex part but you can't get anything on it whilst the bridge clamp is still attached and you can't get that off unless both injectors are lifted together , So that gives me an idea: Cut the bridge clamp (which I think they say should be replaced anyway, then try to twist the injector with a wrench on the hex?
  3. The smoke (LOTS of it) is definitely diesel and even makes the car interior smell as it was drawn in through the heater duct. If I hold the throttle at 30mph I can see behind the smoke thins, but take my foot off for deceleration and day becomes night. On an immediate cold start there's a small amount of smoke, but I can still smell more diesel in the exhaust than usual. When the engine is hot it gets worse. I should have taken a video because I'm not talking a small amount of smoke, but so much you see nothing behind! The HP fuel pump pressure seems ok as is the turbo boost. My theory is something bad has happened to a fuel injector because that's the only place diesel fuel can enter the engine. If it was a piezo control fault I would expect no fuel past the injector or if it was open only the fuel amount up to the size of the nozzle jet. Since this smoke is so huge, I think more fuel is coming through than what I would expect from a fully open conventional pintle nozzle jet, but then I don't exactly know how the piezo injector controls fuel? I do know if I replace one I'll have to adapt it with vcds and I'm not mixing them up! I shall try again to get number 2 injector out. If I have to remove the head I'm stuck getting parts off around the injector which means cutting through and destroying the bridging clamp and possible the plastic cover? I think I need liquid nitrogen on the injector body which I don't have, but I do have a CO2 fire extinguisher to try which I took the horn off. If I can't see any obvious signs of burning or damage to the injectors, I will put them on my airline at 150psi and dunk the tip in diesel fuel to see if there's any leak, then it's pay to have them tested if I can't see anything obviously wrong.
  4. Never had a serious engine problem, but this started yesterday. The smoke in the rear view is so bad you can't see anything and it's off the road. I don't want the dpf filling up with soot either. All the VCDS scans show no engine fault codes and there's no MIL light on. My thinking is there must be a really bad fuel injector, because diagnostics only monitors the electronics and won't tell you if the nozzle has burned away?? I made a slide hammer to lift them up, got 1,3 & 4 to lift up but number 2 is stuck fast. I tried getting the engine hot but it makes no difference. Before I'm forced into the nuclear option to remove the cyl. head and punch it back out, has anbody got any ideas? It's the worst system of injectors I've seen. The only lifting point is under the fuel inlet port and that's off centre. I've seen the service tools, made those and a slide hammer but it's stuck fast. Because they use a bridging fork to hold down 2 injectors, I can't remove the other one tied with the same bridge. If they had designed the hold down bridge and injectors with some common sense, you would under the center bolt which would pull both injectors up. Common rail diesel injector removal ideas welcome!
