MY12 Yeti CR Tdi 70k Belching diesel smoke.
Never had a serious engine problem, but this started yesterday. The smoke in the rear view is so bad you can't see anything and it's off the road. I don't want the dpf filling up with soot either.  All the VCDS scans show no engine fault codes and there's no MIL light on. My thinking is there must be a really bad fuel injector, because diagnostics only monitors the electronics and won't tell you if the nozzle has burned away??
I made a slide hammer to lift them up, got 1,3 & 4 to lift up but number 2 is stuck fast. I tried getting the engine hot but it makes no difference. Before I'm forced into the nuclear option to remove the cyl. head and punch it back out, has anbody got any ideas? It's the worst system of injectors I've seen. The only lifting point is under the fuel inlet port and that's off centre.  I've seen the service tools, made those and a slide hammer but it's stuck fast. Because they use a bridging fork to hold down 2 injectors, I can't remove the other one tied with the same bridge.
If they had designed the hold down bridge and injectors with some common sense, you would under the center bolt which would pull both injectors up. Common rail diesel injector removal ideas welcome!
Edited by voxmagna
typo
I removed a Golf injector couple of months back & found, cleaning up the area with brake cleaner first.
Sprayed some WD40 round the shaft of the injector. Spanner onto the hex part & gently kept moving back & forth.
Started moving & lifted both 1 & 2 injectors. Thorough clean up of injector hole & replaced. 1 hour job.
  1. What colour is the smoke?
  2. If it's white, what's the oil level like?
The smoke (LOTS of it) is definitely diesel and even makes the car interior smell as it was drawn in through the heater duct. If I hold the throttle at 30mph I can see behind the smoke thins, but take my foot off for deceleration and day becomes night.  On an immediate cold start there's a small amount of smoke, but I can still smell more diesel in the exhaust than usual.  When the engine is hot it gets worse. I should have taken a video because I'm not talking a small amount of smoke, but so much you see nothing behind! The HP fuel pump pressure seems ok as is the turbo boost.
My theory is something bad has happened to a fuel injector because that's the only place diesel fuel can enter the engine. If it was a piezo control fault I would expect no fuel past the injector or if it was open only the fuel amount up to the size of the nozzle jet. Since this smoke is so huge, I think more fuel is coming through than what I would expect from a fully open conventional pintle nozzle jet, but then I don't exactly know how the piezo injector controls fuel? I do know if I replace one I'll have to adapt it with vcds and I'm not mixing them up!
I shall try again to get number 2 injector out. If I have to remove the head I'm stuck getting parts off around the injector which means cutting through and destroying the bridging clamp and possible the plastic cover? I think I need liquid nitrogen on the injector body which I don't have, but I do have a CO2 fire extinguisher to try which I took the horn off.
If I can't see any obvious signs of burning or damage to the injectors, I will put them on my airline at 150psi and dunk the tip in diesel fuel to see if there's any leak, then it's pay to have them tested if I can't see anything obviously wrong.
Edited by voxmagna
Quote
There is no accessible hex part on these common rail injectors. There is, but the connector is fixed over the top as part of the return flow. Correction whilst replying: There is a hex part but you can't get anything on it whilst the bridge clamp is still attached and you can't get that off unless both injectors are lifted together , So that gives me an idea: Cut the bridge clamp (which I think they say should be replaced anyway, then try to twist the injector with a wrench on the hex?
@voxmagna That's what I was double checking is that this was diesel smoke and not lubricant smoke. So it's either injector(s) or throttle position.
OK thanks. It's not throttle position. RPM smooth and holds, drives like it did before. Injector 4 came out covered in black gunge, the O ring seal had disintegrated. 1&3 were oily but not as bad as 4. I've not leak tested them yet. I'm assuming whilst these piezo injectors aren't serviceable, the O ring (s) can be replaced? Although they look bolted together like others I've seen, if I confirm definite leak past I might have a go at tearing it down.
I've destroyed a clamp plate now (a tenner each) but it's still stuck. I suspect the O ring seal has gone and carbon is locking it in?  I can get a 29mm open end spanner on the top nut but you can only turn it clockwise tighter and since its not a nut with much width metal, I wouldn't put a lot of force on it. The best way to turn  the injector a couple of degrees at a time is to hit the side near the union with a steel bar and hammer. It's virtually impossibe to get the upwards force, even with a slide hammer.  I'm tempted to make a fitting, attach it to a lifting beam and lift the whole damn car up on then wallop the side with the bar and hammer.
Well I finally got them all out with No 2 being the PIG. I had to break the bridge clamp holding 1 & 2 to release 1 and give more room to work. Tap a chisel down the sides between the forks and the injector body and the brittle forks break off. Still couldn't extract No2. so decided to sacrifice the cyl. head cover (£60) to get more extraction options. Didn't use the angle grinder to cut the cover as it would spew far too much plastic over the camshafts. I used a soldering iron with plastic cutting knife bit to create a hole about 50mm around the stuck injector, then lifted the cover over it.
More huff & puff and before trying the stillsons, I made the slide hammer heavier and took more care to align the impact shock central to the injector. Also removed trhe HP union and used that to hold my slide hammer fixture solid to the injector body. Each slide hammer blow raised the injector about 5mm until it was clear. Checkout the Laser tools injector remover if you want to copy theirs.
Visual condition: Injector 1 oily but clean, O ring still in the groove. Injector 2, Hardly any oiling up, good O ring. Injector 3 oiled up and O ring fragmented. Injector 4 a total mess. with lots of black gunk and hard bits of carbon/O ring outside the injector body, O ring seal gone and groove filled with gunk. The OE seals are 16.2mm ID x 1.5mm. I think they were Buna-N. I shall replace them with 16mm x 1.5mm Viton rings and replace each injector with injector grease.
Parts lists shows O rings at the end of each nozzle and some sell kits with 2 O rings per injector. If there's an O ring on the nozzle, It must be way down at the bottom of the cyl. head and I haven't explored how to get to it yet.
Off to the diesel injector man tomorrow to have them all tested.
Everybody tells me these CR engine injectors aren't serviceable? Not sure what they mean because the black electrical connector body can be removed by the large 29mm nut - watch for the small spring, washer and bypass jet pintle!  After that everything is mechanical.  It looks as though the lower half of the injector body can be separated? I suspect they can be disassembled but you can't get Bosch small parts and more important, measure and qualify the flow calibration.
Onwards & Upwards!
Update on parts: The stock O ring fitted to the injector stem is Buna-N size 16.2x1.5 wht 000 884. I've sourced some Viton O rings 16 x 1.5 and I'll use those. I may even fit a second O ring on the bottom groove, even though it's not machined with square sides for an O ring. The 'Seal' at the bottom of each injector isn't rubber but a copper washer left sitting in the cyl. head which you can hook out. Mine measured 13.36 OD, 7.7 ID x 1.45. There are plenty of Bosch common rail copper washer sets on Ebay, but most are the wrong size. I've found some 13.85 x 7.3 x 1.4 which I think will be ok. Fingers crossed this is an injector problem and nothing more serious needing an engine teardown. The Yeti 4WD diesel is a pig for rear engine access.
Well done you and thanks for the great write up, I'm sure it will help others in the future.
It looks like your hunch was correct, at the time I thought you might be rushing in and inflicting damage due to the stuck injector that may have turned out to be fruitless, I'm pleased yout instincts were correct.
One question. With the benefit of hindsight what if anything could you have done differently that might have avoided some of the difficulties you encountered or told you definitively where the problem lay?
Another question, could there ever be any benefit in re-entering the injector serial numbers and allowing the ECU to recalibrate or does it only work in conjunction with new calibrated injectors?
3 hours ago, voxmagna said:
Check 6: Dynamic injector pressure test: Risky but some do it wearing gloves and safety glasses: Reverse the injector link to the common rail.....................
I'm struggling to visualise what it is you are trying to describe, can you explain it in other terms?
Aha, maybe I have had a lighbulb moment , do you mean remove the injector to be tested and turn it 180° away from the cylinder?
What I would have done differently is less hunch and more tests before removing parts!  Paying for workshop repairs and parts on diesels is expensive. The cost of buying or borrowing some key tools like a leak back test kit (cheap) and compression tester is relatively cheap compared to labour charges. Measuring crank case vacuum is a cheap bit plastic hose and an oil cap. Having and being able to use a digital multimeter is essential for most DIY car work. When you do remove injectors I explained by visual inspection that you can find a lot wrong with them. Having a spare known good injector allows you to swap it with each of 4 and save you injector testing costs.
I also wondered about re-entering the injector numbers.  If you think how they work, the ECU only knows about pulsing the injector in time units and the EFi loop is the feedback to control fuel to air ratio. I think the calibration is only relevant with a new injector where in addition to the air fuel setting, the ECU is being told in advance what volume of fuel corresponds to an injection stroke at constant fuel rail pressure. If you buy a set of recond injectors e.g from Germany, they come with a test report done on a Bosch tester and a new serial number = calibration.  The ECU 'learns' to modify the data after the injector code has been entered which I think is just a tweak of the starting reference point? If the injector is worn then I think the ECU will have monitored that and re-learned. If it hasn't then re-entering the original code starts the ECU learning over again. The advantage of checking your injector codes with the cylinders using diagnostics is if you or somebody mixes them up, diagnostics will tell you which cylinder they go back in.
The short steel fuel lines have the same unions each end and are reversible. Used Golf lines are compatible and bendable.  But you and anybody else should know that injector nozzle pressure for these CR engines is 1800 Bar or 26,100 psi and there are serious safety issues and hazards which would be unacceptable in an industrial workplace environment. When fuel injectors are tested in a Bosch automated tester, they sit inside a clear polycarbonate safety box protecting the operator.  If you search the internet you will find some DIY methods done at your own risk.  The Bosch test kit generates the same working pressure as the HP pump, but in a much safer way. An important test on the Bosch machine is nozzle leakage.  There should be no leakage from the nozzle of a solenoid injector when the injector is at rail pressure and there is no power to the solenoid.  Not wanting to suggest unsafe procedures, I think you can work things out for yourself. 🙂
Edited by voxmagna
Thanks for the warning re pressures.
Regarding the coding if injector leakage or performance and the engine adapting to the wear of injectors over time, having thought about it (you spurred me on) I dont believe it can tell from the lambda sensors etc which individual injector may need more or less time, all it can do is to change the parameter for all of them, from your experience I dont think it does this (for good reason) as with all your excess fuel it would have reduced the fuelling to all of them, or the individual one it it really can (I think not), this was not the case with your car.
I reckon they should be changed as a set (probably the VAG and bosch recommendation) and when that is done the individual figures are used to trim the duration to the individual injectors, that would be why you have to tell VCDS what cylinder each individual injector is fitted to.
So I reckon swapping the position of injectors is a no-no, if you fit a new one is it worth coding it? If the others are still behaving exactly to the original coded parameters then probably yes, I would like you fit it and see how it behaved before deciding if coding would be a worthwhile risk.
It's been very usefull for someone else to have tackled this problem rather than putting it in a garage, it gives me the opportunity to think it through, something that usually only happens when my car is failing and then there are other pressures at play, better to be prepared!
Thanks again, I hope I don't have to put your knowledge to use but I'm sure others will.
Understood and filed in the memory bank!!!!!!!!!!!!!!
Quote
I write notes to myself because it's sometimes not about what to do, but what not to do and fall into a hole next time. I can contribute polished write ups with photos or a video, but there's a tendency for beginners to follow step by step as a problem solver without thinking things through. Problems like these can follow several different paths which may not all apply and there's plenty others have posted on each. What I've tried to do is post my notes and thoughts and it's up to the reader to try and work out what may apply to them.
I did fit and try the used Passat injector without re-coding it first and the engine started up and to my ears appeared to run smooth and fine (with no smoke).  It actually came from a later 2013  CF series engine but not my CFHC. That's why I suggested the 'calibration' is likely to be fine tuning. Since the ECU plays a part in re-learning some values after you enter a new code, I can only guess what these are and they must come from the Bosch automated injector tester which rebuilders use to allocate a new serial number code? These are the variable characteristics I think each injector may have: Mechanical, e.g How the solenoid responds in time to lifting the jet needle (delay?) and how fast it can pulse for higher rpm, volume of fuel let through the injector nozzle from the time the solenoid is triggered to when it turns off.  This would include any lag due to the mass and friction of internal parts, important at high speeds. But how does the ECU 'tune'?  I'm not sure if these CR engines have knock sensors, but that feedback could be used to modify the defaultinjector calibration for minimum knock?
I took the Yeti on a spirited 30 mile fast drive to complete the dpf regenerating cycle and burn off any unburned fuel left over from the fault. When I got back, I wiped the inside of the tail pipe with tissue and there was zero carbon deposit.
I don't know if you've looked at Bosch piezo injectors?  I'm glad I don't have them!  These are more complex and their calibration data also includes a (high) voltage parameter.  Their advantage over the simpler solenoid type like mine is they can turn the nozzle jet on and off 5-10 times faster. This allows the injector, to pre- squirt, normal squirt and post squirt fuel for each firing cycle up to the maximumum engine rpm. You get better efficiency, lower emissions and less diesel knock.
Edited by voxmagna
Whilst it's good to keep the grey matter turning and essential (for me) to keep on top of understanding these developments to avoid having my money spent by a garage who won't have kept on top playing parts bingo, the complexity of my current engine let alone those that follow, hybrids etc, is way too far removed from the simplicity I enjoyed when I first switched to diesel power with a 98 90hp Alhambra followed by a 2001 110hp Octavia.
That simplicity meant such reliability in the first 20 years that I learned absolutely zero about diesel engines , boy  have I had to play catch up going from EU3 to EU4 and EU5, yes the CR is a smooth engine compared to the PD but the MK1 Octavia was smoother and gave equal if not better fuel economy.
