ScoutAngell
Everything posted by ScoutAngell
  1. AUx Pump does it say pump B or C as has 2x aux electric bosch pumps plus main water pump. i had same issue skoda replaced twice under warrenty and still caused fault though me think this cant be like bosch to make faulty stuff turns out if theres even a small amount of air in coolant system will cause the fault to come on. you want to make sure engine gets up to tempurture with coolant bottle off and with some extra reving to heat up will cause any last air to leave leave to cool and make sure water level dont drop causing air to draw back into system. then you shall be fault free. also please remove slica gel bag out off expansion bottle will save you a heater matrix down the line.
  2. Hey everyone, anyone retro fitted heated steering to pre face lift skoda octavia please any tips and places to purchase parts be greatful.
  3. Apart from just swapping screens over what other things do i need to do or will it just work?
  4. Hello, I have a skoda octavia scout mk3 2016, when you press the drive mode button you select which mode on Head unit screen you have options of ECO, Normal, Sport, Custom, OFFROAD. is the a way to change that have just only one option which is OFFROAD so either normal not illuminated switch or press and just select OFFROAD mode only and illuminated the switch??? Many thanks
  5. Is it just a matter of swapping screens from the 6.5 inch to 8 inch anything else i need to do eg coding or wiring. many thanks alex
  6. Hey ken car came with headlight washers but normal halogen headlights it just the led strip drl i want and be normal haglogen bulbs for dipped and main beams unless can retro fit self leveling system for xenon.
  7. Hello any one changed standard front halogen headlamps on pre facelift to the LED DRL version please as would like to on my car but is it just a simply headlight unit change or more like wiring looms and modules involved please.
  8. Anyone got experience playing around with the off road mode settings can you adjust how throttle response and the EDL work. any other options be glad to here about.
  9. I have a 2016 octy with mib2 head unit with smart link actived is there any way at all can connect wireless instead of cable as cable keeps intermittently coming up with connection failed.
  10. Anyone know how if possible to change value of speakers as now show open circuit due to a vibe amp being connected. any suggestions?
  11. Hey i can send you link to retrofit wiring all i cant find is just the cover plate for usb hub
  12. Any luck with this mod with a new panel and parts.
  13. Hello, I have a mib2 ambusan unit sorry spelling not right. It it possbile to add the factory installed sub amp and central speaker would it need new wiring looms and coding etc. Please has anyone done this.
  14. Hello, i have a 2016 skoda octavia scout with a 2.0tdi 103kw 150ps engine CRMB is engine code, since last december when i brought from a dealership have now had 2 coolant pump C replaced due to bring up fault saying coolant pump 'c' stuck. has anyone had this issue with there engine and if so how you gone to fix this as i believe it not the pump it self as its a bosch part and when run actuator test it works you can hear it spinning, so what else can cause this fault to keep coming back maybe a sensor???
  15. do you know which relay it was???
  16. Hello, anyone out there fitted a underseat amp/sub to a mk3 octy to standard head unit ambunsun unit please. need to know if possible and best way of connecting unit please.
  17. Hello, I have a 2016 Manual octavia scout can it be possible to disable the need to depress the clutch to start the engine im guessing this is just a mere safety thing. Cheers Alex
  18. hey i recently last week only ask this question to my local dealer in newbury and yes he confirm it is possible but will need everything sasha has said and cost would be in the region of £3000 maybe more if extra wiring loom needed. so i said thanks but not thanks not worth me spend £3000 plus just to have led DRL's
  19. Hey Sasha if you could send me wd and pin layout this would be fantastic to get working properly on my car as i understand unless you have the electric memory seats this feature will not work properly. Cheers Again for your amazing contributions
  20. yes as ive recently found out those electric coolant pumps are a pain.
  21. was there any reports of this on a 2.0 tdi engine manual gearbox do you have any more details so i can go to my dealer and get it investigated while under warrenty
  22. hello all i have mk3 octy scout 150bhp manual gearbox i am a advance driver and what ever fine adjustments i make to my postion in drivers seat i still fine my car stalls so easily compared to my mk2 scout with a pd140 engine manual gearbox i stall pulling away a few times a week notice thats once i start bring clutch up to bit point the revs naturally drop from around 900rpm down to 750-800 rpm which unless i give it more gas than normal will cause car to stall and getting rather fed up with it all now it seems more the car automatically reducing rpm once in noticing clutch has be started to engaged is there some can be done with settings in coding or something to tell car not to adjust rev postion when clutch is depressed?
  23. tried that still says 14.8gb or have i done something wrong.
  24. Can anyone help with this in terms of new update says you need a 32gb card yet my genuine card that came with the car is only a 16gb card do i now have to buy a brand new card or can i use any sd card.
