Everything posted by brian62c
Rear brakes get stuck over night
Thanks BP and HMR. Useful tips for next time. I did have to admit defeat but luckily she's had no more trouble since so maybe it was mostly the driver's side. I'm going to get the garage to put new shoes on when it goes in, as daughter is moving away from home, so want the car to be as fettled as possible for her 🙄😏
Thanks BP. That looks like where it was on the driver's side. I just sort of prodded it and it worked - the drum pretty much fell into my hands. Now I've had a reminder, I'll give it another go. After that, I'll have to call it a day as daughter needs her car in the morning. It's due for service and mot in not many weeks so if I fail, my trusty garage can sort it for her. She can manage until then. Thanks for your help anyway both. Much appreciated. Long time since I've played about with drums.
Okay, tried towards the rear and there doesn't seem much to see through the holes, unless I look much lower down than the first side. Just a flat metal bar of some sort which doesn't move when poked. Lower down shows a couple of springs close together but nothing that looks like a wedge.
One would think so - but sadly, I didn't think to do something sensible like take a photo while the other drum was off. That one happened so easily, once I'd found a useful little video, that it didn't even occur that I'd have difficulty with the second. Thinking about it, the driver's side was towards the rear, so that may be my issue - I've been poking around mostly on the wrong side! I'll go and have another try while my coffee brews and report back.
One rear brake seizing while parked after rain
Any tips on finding that damn wedge? I'm having a frustrating afternoon not being able to locate it on the passenger side. TIA.
Is there any "trick" or tip to make this easier? I've done one side, clearly by pure luck, but I'm damned if I can do the passenger side. Finding it hard to see much through the bolt holes.
Warning lights after puncture repair
It's been a while coming but finally, here's an update. A couple of days after posting this, I arrived at work, put the car into reverse and parked nicely - then realised there had been no horrible noise and there were no longer any even horribler warning lights on. To say I was baffled is an understatement but I'm happy report that, for the time being at least, all is well in that department. Think I got out of jail, at least for now 🙃
Thanks guys. Looks like it's time for a plug-in baby! 😉
Sorry ords, it did. Forgot that one. Would that bring about all the other issues then?
Evening all, Took my September 2013 1.6tdi to my trusted regular garage for a puncture repair the other day. All good, half a screw removed and hole plugged. Cheap as chips. The next day, the tyre pressure warning binged, so I stopped to check the culprit wasn't looking deflated and went on my merry way home, where, next morning, I topped it up and reset the system. During my commute, the TPMS, ESC and traction control all threw up errors and warning lights, one after the other. No effect whatsoever on the behaviour of the car, so I decided to monitor the situation. On arrival at work, when I selected reverse to park, there was a long high-pitched beeeeep, which stopped when I deselected reverse and came off the clutch. Sounded like an extended version of the rear parking sensor audible warning. Selected reverse again and no noise - but no rear parking sensors either and no diagram on the screen. Been like it ever since. Has this, or anything similar, happened to anyone else? It seems a weird load of things to go wrong all at the same time. Is the puncture repair a coincidence or could it have anything to do with it? I'm thinking I'll probably have to get a diagnostic done and take it from there - but any hive wisdom gratefully received. By the way the car still isn't driving any different to normal. It's done 145k and goes sweet as a nut. Cheers all.
12v socket mystery
I did wonder about that kind of thing, thanks BP 🙂
12v socket mystery
Well, all I can say is apologies for wasting everyone's time - and thanks for the suggestions and moral support. It's clearly good to talk 😊🤪
12v socket mystery
36 is possibly second from left bottom row - but it's a little 10a fuse.
12v socket mystery
Breaking news: It's bloody working now!!! Tried both cameras again in the Citigo. Spare worked, original didn't so swapped the little clear cylindrical fuse in the end of the plug-in bit with a spare cable I had - and that worked as well! It does need the ignition switched on (just so the dash lights up) - which my Octy doesn't - but I definitely tried that before and it wouldn't play ball. Baffled, to say the least 🤔
12v socket mystery
Not like that apparently 😏 46 is bottom row sixth from right.
12v socket mystery
Okay, fuse 36 is a smaller size and only 10a so I'm guessing not right for the 12v socket. It's also completely intact.
12v socket mystery
For sure they don't seem like the most robust of items but I have tried them back and forth several times and with the sockets swapped from car to car. No foreign bodies inside either socket. I'm on it .....
12v socket mystery
Swapped fuse 46 and it hasn't blown again - but the dash cam still isn't working. Don't know about voltage - haven't got a meter. Tried with and without the ignition on - no joy. Also tried a different dash cam - nothing doing.
12v socket mystery
It's 2016 (16 plate). The post I found about which fuse for the 12v socket said 46. Don't tell me I should be looking at 36! 😳
12v socket mystery
Hello all, Daughter's Citigo 12v socket popped its fuse so her dash cam is out of action, much to her distress. I've replaced the 20 amp fuse 46 - which was clearly broken - but no joy. It's not the dash cam itself as I've tested that in my Octavia and it works. It's not the socket either, as I've swapped that into my car and it works. Any suggestions please? I'm no great technical/electrical wizard btw 🙄 TIA
Scout brake light bulb job cost?
Nice one skomaz 😀 A place I used to take my vehicles to lost my custom when, on mot day, they "noticed" a large puncture in one of the tyres - big enough to instantly deflate the tyre. I'd driven 40+ miles to get there ( it was the other side of my normal commute) with no sign of any tyre trouble. Must have happened just as I parked at the garage. What a coincidence! Looked to me suspiciously like a hard stab with a sharp implement 🤔🙄
Thanks both. It wasn't just me then. Just wanted to check I wasn't missing something 😏 Nothing at all against a decent garage charging appropriately for their skills, experience, knowledge and overheads - but this strikes me as outrageous. Unfortunately she's a single woman with quite a posh voice who knows virtually nothing about cars - and I think the garage have quickly realised that. I don't think it's the first time she's been taken advantage of by them. Makes me wonder if there even was a dead bulb! I reckon she ought to go back and politely tell them their invoicing computer must have a glitch because the decimal point should have been one place to the left next to the bulb change. A fiver seems reasonable to me. After that, a change of garage is definitely required. I couldn't trust anyone who'd done that to me.
Evening all, A friend of my wife just had the coil springs replaced on her 2010 Octavia Scout. When she got the bill, the garage had also charged her for replacing a brake light bulb. £50. Yes, £50. I just looked at a YouTube video of a guy changing one on a Mk 2 estate (presumably the same job as on a Scout?). Took less than two minutes, involved no special tools or skills and looked like a pretty ordinary bulb. Is it me? 🤔
Why are Mii wheels smaller?
Many thanks all. Just the kind of stuff I needed to know. I won't worry about 14" wheels now 👍
Afternoon all, Been looking for a 2016 Citigo to replace my daughter's which unfortunately she wrote off. Not much suitable in our budget around so looking at a Mii. However, they seem to have 14 inch wheels instead of the 15 inch on the Citigo. What difference does this make, if any? Are they any more expensive to replace? How do they affect the ride? Cheers.
