Everything posted by Ads230
Has anyone fitted an APR Billet dogbone mount?
It sounds like you and I are running basically exactly the same cars 👍 - manual 230 hatches (albeit yours 2 years younger + FL), both Stage 1 Racingline maps with 330bhp, both 235/35 R19s. I should have added that the APR and 034 (without the additional part they require) mounts do operate exactly the same and have absolutely zero discernable difference in NVH properties from each other. I did see your other thread, I think I also commented (can't remember!), but given what you've described, I'm pretty convinced that the noise is axle tramp under the increased power - especially since we've extended stock BHP by +100 or thereabouts. Mine did it before I replaced the mounts, although I don't tend to pull away hard that often to save the stock clutch for now. Personally, I would go for it to see how you get on with it 😊 It's not an invasive mod, it's not that expensive for a test, and it's fully reversible - so long as you ensure you replace the bolts each time to prevent stripping.
Evening! I've had both the 034 Motorsport billet alu and APR stainless steel fitted to mine for the past 2.5 years; the 034 first, and the APR one earlier this year due to 034's admittance that additional strengthening was needed to avoid warping - which, once removed, had not occurred on mine. In terms of noise, vibration, harshness (NVH) there is a noticeable difference in all those areas, but personally it's not that much. It's obviously difficult to describe on here, but I feel it mainly in vibrations through the floor. Everyone has their own tolerances around NVH and is totally subjective. For me, it meets my tolerance level but then again I have stiffer springs and an aftermarket exhaust - so it only adds minor NVH to what was already a noiser (AKA "more purposeful...") car. I fitted it because I wanted reduced (if not eliminated!) wheel-hop, better manual gear changes, and peace-of-mind knowing I had some better components fitted to make the car 'feel' sportier, since it's Stage '1.5' remapped (additional components on Stage 1 map). Gears are easier to select and the manual throw is much less vague - not that it's a bad 'box to begin with, but you definitely get a lot more consistency with the 'felt' changes. It really optimises the car for me, and makes it even more enjoyable, so for that reason I can stand the NVH. Based on your initial post, if you want a 'smooth drive', it's perhaps not the best choice for you as it never really 'beds in' - you just get more used to it. In real terms: Noise - it took about 1 week for me to get used to it on daily drives, but doesn't add a great deal (especially not to mine). It's just more noticeable at lower revs. Vibration - You'll feel it in low rev maneuvers a lot more; reversing particularly. This does add to the 'harshness' factor, but the fix is to rev more OR just get on with it... It feels a bit like a 90s diesel Volvo occasionally, especially on cold start up. So if you do a lot of stop-start / commuting, it's probably not a great idea if you want a quiet, comfy drive. Harshness - The only thing I can add here is when you release the clutch without accelerator for a slow take-off / maneuvers, you'll feel more vibration. But it doesn't affect the drive much IMHO. If anything, the 'pros' that I added above re: accuracy of gear changes and the 'tightening' up of the whole car under revs is hugely addictive. I personally love it, but I am aware that I've optimised mine for performance where it counts, rather than make it the comfiest it can be. Swings and roundabouts 😃 My recommendation would be to really consider what you want to achieve by adding it, and whether it'll bug you having the vibrations. Good thing is it's not an expensive part to buy or fit, and - so long as you replace the bolt each time - its's easy to refit the old one if you test the APR one for a few weeks / months. EDIT: If you do go for it, be sure to identify the right part as there are 2 different shapes available depending on your individual car.
NOx & remap.
@Stuart-h - Who did you use for the re-map? If / when the dealership identify that the car has been remapped, they may directly attribute the 'fault' to the map and will charge for it outside of warranty. Wouldn't know costs of replacement / fix, as they haven't yet identified the root cause yet. It would be worth calling the re-map company to query if they've experienced this sort of issue post-map before with other customers, and if there is a fix for it. If not, it's still useful information for them so that they can log these sorts of issues to identify any trends going forward.
Wheel fitment
Hi Steve, welcome to the forum. There are a lot of posts about wheels and fitment (for future info, you can also use https://www.willtheyfit.com/ for aftermarket wheel checks to your car). The OEM wheels from Octavia VRS Mk3 were either 18" or 19" sizing. Both should be standard fitment in terms of wheel hubs / bolts etc. To get more specific advice from others in this forum, it would be good if you could specify what size wheels you're going for (or provide link) and any other information with EBay post? I'm no expert in this field and looking to get a/m Neuspeeds anyway, but used WillTheyFit etc to verify fitment. Things to consider will include: - Increasing the wheel diameter may affect your speedo calibration, so you might need to get it re-calibrated (Skoda may be able to assist, or any VAG specialist garage) - You may still find that without suspension changes, there may still be a larger gap than expected re: fitment between wheel and arch. That's a minor thing, but some expect wheels to fully fill these but might just raise the car slightly. - Unsure what larger wheels will do with stock 'SE Technology' spec suspension, not just in terms of harshness but also any extra wallow etc. since they're not the lightest wheels around and adding unsprung weight might unduly affect performance of the standard car.
Banging at the front when accelerating and hitting a pot hole.
Doesn't sound like it's the lower engine mount in your case, then - seems more likely (as you've highlighted) that it's suspension related (i.e. hitting bump stops) OR heatshields OR exhaust hangers that meet their tolerance limit and connect with something... If it only happens occasionally under certain conditions, theoretically it would be easier to nail down - except it's hard to repeat those conditions without nailing the car a lot. As an aside, replacing the lower mount is an excellent mod (particularly in a FWD car with upwards of 260bhp) and IMHO the additional NVH is minimal in the TSI's. That said, everyone's taste is different and I'm aware the 'tuners' have got a bigger appetite for NVH than others. Considering the parts are ~£50 and easy to fit, it's 100% possible to try and rollback if it's not for you.
What is it with dealers and their inability to set servicing schedules?
Another simple fix is to never use a Skoda dealership for servicing, and switch to a specialist VAG or tuning garage. (I understand that there are massive dependencies on this, including whether or not you need to maintain guarantees / warranty / PCP clauses, as well as higher costs potentially etc). However, independent garages have a reputation to uphold and more often than not deliver vastly superior service, with better knowledge. Rather than typically lower quality, high quantity work that most dealerships provide. If you can't trust them to fix a simple issue after multiple requests, how can you trust them when it comes to the bigger stuff? And if you care about quality work to the vehicle, it's a no-brainer to move to a VAG specialist. Either way, all should have checklists of some sort to ensure that requests for resetting servicing intervals etc are completed to stop the inevitable pinging on every start-up!
Low end of "Normal" for engine oil temp
Like I said @EnterName 😉 All proper useful info though, I've learned a lot reading through all this.
Going too see and drive my first ever Octavia VRS 245 - need some help please
This is a good point to raise. As someone who happens to work in this area (security, mainly) - if anyone at the garage raises 'GDPR / UK Data Protection Act 2018' as a reason not to show you receipts from previous owners etc, I'd advise the following: A) ask for the clause in their privacy policy regarding this (i.e. don't let them fob you off with a made-up / half-understood "store policy" approach). Read what it says and/or ask them to explain their justification. and B) ask them to anonymise any documentation (e.g. scan / photocopy and black out the previous owner's address). As a potential buyer, you have a justifiable reason ("legitimate interest") to get written assurance that the car you are looking to buy meets your requirements and expectations. If it's within the capability of the garage / seller etc to anonymise documentation, which they will have to hand somehow (unless they're utter tools), they should do so. You're not looking for who owned it; you're looking for what was done to the car, when - as per normal car history stuff (e.g. servicing intervals, modifications, repairs etc). It's probably a minor point to raise, but I'm sick of common sense and genuine requirements from legitimate interests getting arbitrarily blocked through ignorance of data protection legislation. #NerdRantOver 😉
You'll probably get 1000 different academic answers from this wonderful forum, since it's all dependent on the engine make/model/tolerances & oil spec used within the engine 😉 As a general rule of thumb (& as I'm sure you're well aware), the indicated coolant temp meets its 'normal' level much faster than the oil itself. Oil takes a while for it all to warm up and become less viscous, therefore putting less friction on the engine components & doing its job properly. Personally with my VRS, for example, typically sits between an indicated 95 deg C (which I regard as the 'cool end') to 105 deg C (usually 'middle' - e.g. motorway driving). I'd consider 'Hot' to be 115 deg C+ in normal driving, unless doing track days etc. I'll take it gently for the first 5-10 minutes of driving where it starts increasing from the indicated oil temp from 50 deg C -->. My personal approach is to wait until it hits 90 deg C, where I (subjectively) feel that it's "warmed up" to allow more spirited driving etc; but appreciate others might think differently. I'm not sure there's any definitive answer online unless someone is a verified VAG engineer, but typically anyone with mechanical sympathy & understanding will limit any spirited driving or overrevving until the oil meets at least 80 deg C, where it starts to reach its operating temperature.
