Everything posted by 59p
Creaking noise on full lock and slow speed
The noise went away itself over time. Not sure how or why.
Clutch pedal sticking
Wow £1200 to repair, assuming this includes replacing the clutch and flywheel?
Yep, but if its the slave (always get the two mixed up) clutch and flywheel may as well get replaced and thus becomes a rather expensive repair!
Hi no, didn't get to the bottom of it. Ended up selling the car and won't look at any German VW group car going forward, far too many reliability problems with them.
Clutch pedal sticking on Octy VRS Diesel
Never heard about this mod and not sure if it would be the same on the Octy - you'd imagine it is, however the mk3 Octy is based on the MK7 Golf so could be different. Did you replace your slave cylinder and was the clutch/flywheel also done at the same time?
Is it worth bleeding the clutch to see if this helps? Or is there a bigger risk to having this done, i.e. slave cylinder failing completely?
Seized Glow Plug - Cylinder 4
So after a week or so of spraying the Glow Plug with PlusGas, it still wouldn't budge this morning and mechanic wasn't risking snapping it. However, the EML has gone off and not sure why! Not cleared the error code so kinda confused, anyone know why?
Have been spraying with PlusGas for a couple of days, noticed quite a bit of it just sat around the glow plug - is this actually going down into the area and is there any issue with it being sat where it is?
Well ordered some PlusGas, will give this a blast over the coming days to see if it free's up the glow plug.
Agree and the car has been running fine with the 3 working plugs, however I have a EML on which is annoying to see every time I drive the car.
Gonna give this a go.. Question though, were you glow plugs seized or did you attempt to remove before using the Plusgas?
No its defo this as the code was cleared and then returned a few days later. I'd like to change the faulty one but its proving rather difficult to get it out lol
Do I carry on driving it until they all fail? It's just that if I come to sell the car, can't be advertising with the engine management light on.
So mechanic sprayed some form of lubricant or wd40, left for a few hours.. Even took the car for a brisk 30min drive to get engine nice and hot but made no difference.
Looking for some advice, had my engine management light come on last week when weather was a little colder than normal. Got around to plugging into VCDS and was presented with the following error code: 497 - Cylinder 4 Glow Plug Circuit (Q13).... And some other text Took the car to my local garage who confirmed it was defo a faulty glow plug however, the plugs would not budge and he didn't want to risk breaking them. Now the car starts and drives perfectly fine but I have this management light on even after clearing the fault! What are my options and is there a way of getting these seized plugs out?
I'm hoping its not this as its likely to be an expensive repair!!
Thats the problem, all the threads I've come across don't really get to exact cause.. Unless you know of a thread that addresses the issue?
So this started around few weeks ago and has progressively got worse! Clutch pedal is not returning fully after being pressed and only when I pull it up by hand (at a stand still) does it return to normal and will function as it should briefly. No issue with changing gears, no slippage etc.. I'm lead to believe its one of cylinders (master or slave) but not sure which one. Also will this require a clutch and flywheel replacement?
Mine has started doing this, sticking when pressed and not coming all the way up when released. Having to manually pull the pedal up with my foot or hand (at a stand still). Is this going to be an expensive repair?
Clutch not returning, stuck in gear?!
Experiencing something similar to this on my mk3 VRS, clutch pedal is fine when pressing and engaging the gear but fails to come all the way up, usually returning a third of the way up! Not taken in to have it checked but what is it likely to be? If its one of the cylinders, how much in labour should I expect to pay?
Creaking on full lock
Really? What sort of milage has your Octy done? Do let us know what the issue is when you get chance of have it checked.
Did you ever get to the bottom of yours? I'm getting the same on mine, only when turning right full lock at very slow speeds
Still not had chance to get this looked at, does the video help at all with identifying where that sound is coming from?
- link to video.
I'll try getting someone else to look at it but will also try attaching a vid on here if possible. If not, will upload to YouTube and share the link.
