Everything posted by Dillaz_k
Fuel pressure regulation- control difference
Hi, Researched this fault code can't find anything online anyone else experienced this? Anyone know what control difference means in the fuel pressure regulator? Fault code p106500. Picture attatched
- Does skoda octavia mk3 vrs have pcv valve?
@Skully27 no i didnt change pcv valve from what mechanics say (vag specialists) it dosent have pcv valve only petrols do. I have had my turbo checked no fault no smoke if it was engine related i.e pistons/rings i would see white/blue smoke no smoke at all. Had vag specialists look at the car and they dont seem to know what the issue is. Seems like nobody at all knows which i find weird. Ive been following alot of these forums even the seat and vw forums same engine fr 184 and gtd since 2018 no solution in any forum to our oil consumption problem.
Skoda Octavia VRS 2.0TDI (CUPA EA288) high oil consumption
@BogdanBHow much you looking at for a repair if it is the pistons/piston rings?
@eacaee you changed the pcv valve? Has this cured the oil consumption issue?
Rough idle
@bharvey1963 did you manage to sort it im getting same fault code
Fault code P106500 fuel pressure regulation control difference
Hi, I am getting fault code fuel pressure regulation- control difference code P106500 erased code re appears after a day or two searched what this could be can't find answer. Not much on the net regards to this. Any help would be appreciated. Many thanks
What is this part?
@sessions yeah the part ending b is twisted if you look online @encephalopathy nice one pal
- 11 replies
- bush
- bushes
- rod
- suspension
Tagged with:
What is this part?
What car do you have and what did you upgrade to? A thicker arb? @encephalopathy Also does anybody know if there is any difference between 5Q0411315b And 5Q0411315a One on my car is the B seems like a hollow bar compared to the A ive bought the A one as it looks better quality but both fit my car skoda octavia mk3 vrs 2014 Is a solid bar better than hollow bar? Pictures attatched
- 11 replies
- bush
- bushes
- rod
- suspension
Tagged with:
What is this part?
Nice one pal thanks for the help 👍 Best to change both or just the faulty side?
- 11 replies
- bush
- bushes
- rod
- suspension
Tagged with:
What is this part?
Does it come as a complete unit? All one piece highlighted in green and blue?
- 11 replies
- bush
- bushes
- rod
- suspension
Tagged with:
What is this part?
Theres a similar rubber at top behind the nut is this a bush? (Blue) wondering does the nuts need tightning to get rid of play or the rubber booting need replacing is there a bush in there or is it just a boot?
- 11 replies
- bush
- bushes
- rod
- suspension
Tagged with:
What is this part?
Was wondering what this part is pciture attatched. Makes a noise when i turn the wheel to the right ( creaking) 60%+ more when stationary. I wobbled the metal rod theres play and makes the same noise when turning (green) the other side is solid. What is the other parts connected to it top and at the bottom (blue) Any help appreciated Thanks
- 11 replies
- bush
- bushes
- rod
- suspension
Tagged with:
@Srkigtd It would not damage your engine by using 5w40 oil although it would damage your dpf though if you have one equipped to your vehicle. So wouldn't recommend 5w40 with a dpf.
@Virusul Hi, what was your oil consumption before using ulei motor ravenol 5w30? Also which oil was you using before ulei?
Can i use 5w 40 (no dpf)
Nice one for your help lads @Wino @MarkyG82
Question is will 5w40 be fine in my engine instead of 5w30 even though it don't sort my consumption worth a try?
Lol i have been and now I've had dpf out thought I'd try a thicker oil see if it helps even if it is a little. What you mean by that far gone there is nothing wrong with it it's just the engine i know 2 other people with same spec car same thing. Cupa engine code. The cuna ones are fine.
There is no issue with the engine have had it fully checked i bought the car on 30,000 miles it is now on 108,000miles it has used excessive oil from the day i got it now it's getting slighlty worse. It used to be 1 litre/2000miles now its at 1litre/750miles. I think its the engine that just burns the oil to be honest. That's why im enquiring about a slighlty thicker oil although 5w40 is a pd engine oil would it be safe to use in my cr engine?
@e-Roottoot price isn't the issue, the issue is high oil consumption so thought id try 5w40 slighlty thicker wont burn as bad at higher operating temps as 5w30. @Wino would it be ok using 5w40 505.01 instead of 5w30? Any side affects or is it safe to use in this 2.0tdi cr engine. Thanks. I service my car every 6-7k
@MarkyG82 If you can't answer my question please don't reply topic clearly says can i use 5w40 not the legality around a dpf. Thanks.
Hi all, I was wondering can i use 502, 505 5w 40 instead of 5w30 car is 2014 skoda octavia mk3 vrs 2.0tdi cr. It no longer has a dpf in the car so would this be fine using 5w40?
Misfire at idle is normal?
Just noticed this on the fuel lines could this be the cause? No hole or rip but seems burnt somehow.
It has the standerd map all he did was delete egr and dpf. Spoke with him already.
