kacluk
Finding my way
Everything posted by kacluk
  1. suggests looking at the andoid vagdpf application. it helps me in my on my 2016 2.0tdi for a year used mostly in the city at short distances and the dpf light never came on
  2. I look forward to seeing the results. If it would be that simple and below £ 500 it would be a great deal for me. Maybe it's like with a rear view camera .. it's enough to buy it for about £ 16 and it works perfectly.
  3. Hello. Of course I can give you a link where I bought it. Aliexpress camera I also add dynamic indicators that look much better than the factory ones dynamic blinkers for skoda superb
  4. No problem. I hope you can do everything from my photos. Let me know how everything will work. The worst thing is to connect the camera's power supply. I didn't want the camera to have power all the time, so I was trying to connect to the cable bundle and find those from the reversing lights
  5. Sorry, maybe I explained something wrong, because I led my cable at the bottom of the doors. Under the beige plastic door covers (not sure how it is called inEnglish). Please see pics.
  6. I started lining cable from radio control unit form behind the glove box and then along the door skills (without removing them) and then behind the back seat and then in the back left corner to get to the roof all should be clear from the attached photos
  7. sorry for replying so late. So as for the coding, it's a very simple job. My skoda is 2.0 tdi dsg 2016. when you connect to obd eleven, you need to enter CONTROL UNITS and then you are interested in the MULTIMEDIA 5F and PARKING ASISTANCE 76 modules. LET'S START WITH MODULE 5F: You enter the long coding option and look for Byte19_rear_Viev_low and change the options to Acvivated. then you go to module 76 and with the same long coding you look for the camera type option. you can try to enter these options in obd11 without connecting to the car I hope I helped you. if i am from corby / kettering area and i can help if you need to.
  8. that's exactly a flare. I did it as a celebration when I was able to connect and code the reversing camera for all £20 🤣
  9. Here is mine 2016 executive. 2.0tdi 150ps dsg...
  10. Hello. I was able to set up a reversing camera without dynamic lines from aliexpress for the amount of £ 16 .. Everything works as it should .. I did the coding using obd eleven..
