Mobear
Everything posted by Mobear
  1. Ok i have a look and update thank you
  2. Hi i got a skoda fabia 1.4 16v petrol 2005 the engine light was on and i had code p0401 so i cleaned egr vavle and the pipe and the tb then cleared the code and come back after one day the code was p0402 this time i checked everything but not sure what it can be any ideas Thanks
  3. I sorted my problem it was less mix in the washer bottle causing things to freeze up and something was stuck in the rear washer jet nozzle now its way better the water gets right to the top and i checked all the connections they was fine but the one inside and near the rear wiper i put shrink tube on so they don't come off the only ones that can come off are the ones that are in the engine bay and under washer bottle but they are easliy accessible so don't need to worry about ripping the plastics off Thanks for your advice
  4. Is that a new pump that i have to get or can i repair it and yes i have put in stronger mix now but might be to late
  5. I did try it after a 30 min drive was the same thing the pump was frozen tho but after 30 min drive it worked but just had the problem no matter which way i pressed the stalk the water came from front
  6. Hi I got a problem with my Skoda fabia 1.4 2005 when i push the stalk to activate the water jets forward or backwards only the front works both ways. when one way is for front washer and other way is for back use to work fine but it only started with this cold weather can someone help please
  7. hi i have a Skoda fabia 1.4 2005 petrol I changed the break shoes one side is perfect and the problem is the driver side turns easily but when i put the little t30 screw on its really hard to turn the drum but when i loosen it. it starts to turn fine so i loosen the t30 screw and put the wheel back on same thing its hard to turn and took it for a drive and the drum gets hot I opened it 10 times and cleaned it few times and checked the adjustment tab thing its fine. can someone help please Thank you Got a feeling it might be the drum that is bent but dont want to buy it if its not that
