Bepis
Finding my way
Everything posted by Bepis
  1. Not aware of the specifics of this retrofit but found this after having a quick look on https://ifinterface.com/page/page3.php?langid=2. Seems the part number is 7P6 907 357 E Z00. Hope that helps
  2. Having a similar issue but the boot can open using the button on the key fob. The boot is shown as open on the MFD when it is actually open however the button on the boot itself doesn't do antyhing. I have access to VCDS and it shows the boot latch actuating(off-on-off), the car recognising the boot is open (switching from to - for), and the "status of rear lid lock" is always "released" but nothing changes when I press the button on the boot.
  3. Fitted the bulbs today and they look great and are much brighter as well as the indicators now being instant on-off . As expected the car didnt like the bulbs but changing the load type of the bulbs using VCDS fixed that. For anyone looking to do this the Bulb IDs and coding are as follows: Module 09 Cent. Elect. > securitry access > 31347 > Adaptations Indicators (doesn't include the repeaters on the side mirrors): Leuchte0BLK VLB35-Type_Of_Load_0 Leuchte1BLK VRB23-Type_Of_Load_1 Leuchte18BLK HLA71-Type_Of_Load_18 Leuchte19BLK HRC10-Type_Of_Load_19 These all need to be changed from "Blinkleuchten" to "LED Blinkleuchten" Reverse lights: Leuchte28RFL C3-Type_Of_Load_28 For me this originally appeared as "unknown" so I changed it to "LED Bremsleuchten" which roughly translates to LED brakelights but it seems to work without any errors on the dash or in an autoscan. If you tested the bulbs before coding them then you will have stored fault codes stored in the central electronics module that won't appear in the infotainemnt or on the dash. Thanks you @langers2k for your help
  4. From what I could find online its the "lasttyp" that I need to change to "LED Blinkleuchten" so the BCM sends the correct PWM signal and expects the lower load of an LED. Is that correct? Also are those bulb IDs for the indicators in order from front left to rear left? Am I also correct in thinking that the reverse light bulb ID is Leuchte28 even though there are 2 reverse light?
  5. Never done an adaptation map before but I think this is it. adpmap-09-6C0-937-089-C_TMBFN6NJ3GZ16-20201218-1621.CSV
  6. I'm looking at fitting some LED indicator (front and back) and reversing bulbs but cant figure out what the bulb IDs are so I can change the load settings to prevent a "bulb out" error on the dash and hyperflash indicators. The car is a MY16 Fabia Monte Carlo with the front LED running lights and projector headlights. The BCM is a 6C0 937 089 C. As far as I'm aware it should be leuchte(bulb ID) but there are quite a few adaptations that contain leuchte and them being mostly in german doesn't help things. There doesn't seem to be much information regarding bulb IDs so any help would be appreciated.
