Everything posted by Rubaj
- Fog Lamp Change
AC panel blinking
Nothing i checked it in vcds
AC panel blinking
Hi! I have this problem, it’s looks like it turn off and on. Did someone have a solution for it? 2020 superb 2.0 diesel https://files.fm/f/nkftxsh6yv
- Head lamp LED become yellow
Lane Assist - Coding
I am from Hungary. Yes it have 2Q0 camera. I got the coding from here: https://www.vag-coding.fr/skoda/superb-3v/superb-3v-facelift-activation-du-lane-assist/#google_vignette It is a clone one, with STM32F429 chip and the 25.6 vcds version number.
Hi guys! I wanted to code and apply lane assist to my 2020 superb mk3 fl. But when i wanted to do the security access code it denied. I used vcds 25.6 and tried so many codes. Can someone help me with it? https://imgur.com/a/84RGlFJ
Amundsen MIB2 Firmware Update
Yes now it is available as you wrote. Thank you!
Hi! Can someone send me this update? :) MST2_EU_SK_ZR_P0480T
CanBus Adaptor - to fit the newer Skoda (silver thumb wheels) steering wheel onto an older model
Hi! I want to upgrade my steering wheel too. Can you give me the wheel’s oem number? I don’t have adaptive cruise control in my car so i want the version that see on the top picture. Or is it matter if i buy the one which got that button on the top right corner or not? (It is a 2020 fl, sportline, DSRB Engine code)
EPC Light + P00AF
Hi! So it happened to me second time, while i was in a hurry around 180km/h the car's EPC light appeared and the vehicle like powerless. Plugged in my obd device and it shows me this code: P00AF - Turbocharger/Supercharger Boost Control A Module Performance. I wait till the oil cool down, turn off the engine then turn on. Epc light disappeared and the car got power again. Battery has been checked in a store that sell these and they told me everything is fine about it's battery. Did someone get this trouble too? What is the solution in this case? ( 2020, 2.0tdi, 150hp, not chipped)
Display software upgrade
Hi! Few days ago i bought my first superb. (2020,FL) My question is how can i upgrade the software firmware? Here it is what i got now. And is it possible to connect Apple CarPlay with bluetooth and without cable? Thank you!
Brake pad knocking
I used ceramic paste on the back side of the pads, it works well not a single knocking sound
Heater Support Pump
I tried to clear the fault code but it appear everytime. The car got 280.000km, he had to remove it because of the work procedure. He do not have time for it in this month, and i am a taxi driver and i need the car to work.
Heater Support Pump
Hi Guys! I got a 1.6 CR TDI skoda octavia.(2017,DDYA) Yesterday my mechanic had to change some of my heater support pump (because he broke it and installed an aftermarket one), which is in the back side of the engine, under the DPF filter. So now i got engine light on. This is what my vcds show: 1 Fault Found: 27166 - Heater support pump P16CB 00 [175] - Supply voltage MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 279420 km Date: 2023.12.04 Time: 17:03:32 Engine RPM: 2051.50 /min Normed load value: 57.3 % Vehicle speed: 17 km/h Coolant temperature: 92 °C Intake air temperature: 26 °C Ambient air pressure: 990 mbar Voltage terminal 30: 13.781 V Unlearning counter according OBD: 40 Heater support pump 1 bank 1 second.circuit: activat.: 94.17 % Heater support pump 1 bank 1 primary circuit: activation: 95.00 % Heater support pump 1 bank 1 second.circuit: activat.: 94.17 % Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.: 35.94 % My main question is: Do i got the error because of the aftermarket heater support pump or another one got bad? I attach a picture, where you can see the test datas. Thank you! (Sorry for my bad english)
Floor "carpet"
Hi! Can i buy this type of "carpet" as seen on the picture? (It is under the floor mat.) I don't want to buy the whole one, i just need a little material to replace and i want to match with the factory one.
Vin decode request
Hi guys! Can someone decode my vin number? TMBJG7NE0J0041954 I want to use it in vin creator(etka 8.3). Thank you so much!
- Strange noise from the suspension
Hi guys! I have a strange noise from near my suspension from the front. Already changed the anti roll bar bushes, bushes in the suspension arm (both side, and both bushes), engine mount (under the engine not the top one). Used lithium grease all on my changed rubbers or bushes. Did someone have the same noise or have a solution for this? VID_20230523_174402.mp4
Front brake pad moving
I grabbed it and push up and down, not side ways.
It's a bit more than 2mm of the moving. The brake got almost 12-15k km in it. And it makes that clunk noise....
Hi! I got a 2017 skoda octavia with FS3(brake caliper or system). Is this moving is alright? 319940292_5770185609685034_5313930956479299650_n.mp4
Rear brake pad size
Thank you so much!
Rear brake pad size
Hey! Silly question but if i search on it i got two types of pads, and discs. I want to change my rear brake pads and discs( both of them will be TRW) i just need to know the sizes of them. Thank you for your repyl! 2017 Skoda Octavia 1.6 CRTDI DDYA 85KW 115HP
