Everything posted by Rubaj
Brake pad knocking
I got the same problem as the one who wrote the topic. 2017 skoda octavia with 1.6 cr tdi is the patient. It have an ATE discs and brake pads like in the picture. Did anyone find a solution for the "clunk" noise? Or if i install those anti squeal self adhesive break pad shims will stop that frustrating noise?
Facelift headlight change
Hello guys! I have to change my front right headlight because it cracked so bad(front side of the headlight). Just want to know that Do i have to get the same year of the headlight? If i change it do i have to code something? ((It's a led headlight made in 2017)) Thank you for your replys!
Skoda Octavia 2017 FL Led Headlight
So yes it disappeared but today i see it again. It was just in one headlight as before. I hope there is a solution for it or should i need to remove the whole headlight to check it?
Thank you for your reply! I tried it today but nothing happened.
Hi Guys! I got a 2017, 1.6 crtdi, DDYA Octavia with LED headlights. The main problem is that everyone know. Some fog in the headlight, but in my case it just in the right. (yeah i know it will be disappear but it's not.) So the left one is full clear. There is no crack or something like that, my question is. Is there any ventilation thing? How can it cool down itself? I ask it because maybe its clogged. Sorry for that stupid question but i don't want to pay a huge amount of money to buy a new one. I hope there is a solution for it.
MK3 FL 2017 water pump and timing belt change
Yeah i will buy the genuine pump and if it's an option an analog belt kit. Thank you so much for you help!!!! Have a great day!
I would like to ask you to, can you recommend me some analog type of this water pump? I am so sorry about my knowless but i wants to buy the correct type of pump.
Wow thank you so much! Is there any chance that i get from this type of catalog about my car?
Ups sorry i forget the code DDYA
Hello guys! I have a 2017 octavia with 1.6 CR TDI engine (115HP). The time is here when i need to change the water pump with the timing belt. Searched for some kit and i found this one. https://www.autodoc.co.uk/gates/13671357 Is it good in my car? I asked that because of the water pump and there is non switchable and switchable pumps. ((My mechanic will change everything, i just wants to buy the kit)) Thank you so much!
Skoda Octavia 5e5 Front Break pads
I don't know, because i ordered with vin number. So i checked this website and picked the analog one. I choosed the Bosch one here, with Bosch discs too. https://webautocats.com/etka/part/5Q0698151C/
They used Bosch so not skoda/vw parts. Ordered it with VIN number. But if its the main problem, can you recommend a good type of pad? Here it is a pic. It was factory one before the change and it looks like they used clips
Hello guys! I got a problem with my break pads. If i hit a pothole, or a little poppin can be hear a knock sound from the pads. These pads are brand new ((like my brake discs)) but my mechanic told me that they can't do anything with that noise.... They used copper paste too... Is there any solution that work? Like clips or someone who had the same problem and fixed it? Thank you so much!!!!! There is a youtube video with the SAME problem: Skoda Octavia 2017 FL 1.6 CR TDI DDYA
Amundsen MIB2 Firmware Update
Hi guys, I wanted to update my mib but it didnt work. I tried everything. (hold the menu button then upgrade my software, use sd card format it and then install it but it sidnt work.
