DutchVRS
Everything posted by DutchVRS
  1. Yess i have an estate. But the DCC is still working fine in 99% of my driving. But sometimes on a a puthol ish I suspect the dampers should act differently. It smashes through now on normal mode. I drive between normal mode and max sport.
  2. Wheel allignment to be done for sure. I have a report of before and after lowering. During wheel allignment a good garage also does recalibrate the radar. I did not recalibrate the dcc. Still looking into that who can do it. Lowered with Cobra springs nowm
  3. Quick update; put in the 15" AudioSystem ASS15 sub and placed the 8channel DSP. Wiring to be done and amplifiers placement👌🏻
  4. Front door panel to be removed with screw on side behind small cap, 2 torx bolts behind handle and turn a bolt 90degrees at bottom of panel near the projector light. Disconnect some connectors and water hose for umbrella and panel can come off with some lifting and force.clips will not break when temperature is above 15 degrees C. Most likely golf 6 speaker adapters can be used for the midbass speaks, but thats what i have to confirm.
  5. Quick update, not having a lot of time these days. But now ready for placing the amps, wiring job, mounting sub. And make a plan for the cover panel which will become something special.
  6. An active subwoofer can be used with high level input speaker signal coming from rear door speaker signal (or front of course), I need to check color coding. Most new active subs, or small new sub amplifiers have auto-turn on function; so no separate remote signal needed. However, you need to get +12V from battery to back. ground can be put on backseat belt bolts (after grinding the paint).
  7. That looks nice! Not gonna mount a protection grill?
  8. These will be the components STEG MSS1 tweeters in A-pillars STEG MSS6 midbass drivers in front doors STEG SQ32 tweeters in rear doors STEG SG650C midbass drivers in rear doors STEG 2x MSSK130.4 amplifiers for the speakers Audio System Italy 15inch subwoofer, ASS-15 in sealed setup enclosure 62Liter Audio System F2D1000 subwoofer amplifier STEG SDSP68 digital sound processor
  9. Maybe these pics are interesting for you guys👌🏻
  10. Progress is slowwww😅
  11. Maybe I should make a separate thread about this audio build?
  12. Work in progress😄 Will fit 3 amplifiers and replace all speakers and a 15inch sub in the spare wheel area, all driven by a dsp connected to the HU.
  13. yess thanks! Do you also know how to turn of start/stop?
  14. Wondering who already got deactivated start stop? Yesterday we managed to through vcds and with a token to get lane assist on last setting.
  15. Good question! Also want to deactivate the function.
  16. Hey hey, did you already speak to Skoda dealer about it? Wondering what they have suggested you.
  17. Aaah yes that was what meant. Mine up and down stopped working partly.
  18. Could you try if with the round button up and down works for you?
  19. Yesss good to see I am not the only one haha. Please claim it asap😁. Skoda is now aware of mine. Will book the car for repair in September.
  20. Unfortunately they have to take out seats and investigate...really doubt if they can do this without messing up the seats....
  21. Are you guys able to test the round button and push it down and up? You feel changing the push?
  22. Hi! I was just trying again massage seat function again but noticed the up and down part of the back isnt working so much anymore as i recall from 2 months ago. The function in the back from pushing out and pulling in works just fine. I can also hear the motors but looks like it lost it strength? Anyone else who is experiencing this?
  23. Will make some more soon
