Szogun
Everything posted by Szogun
  1. Yeah - it can be done without replacing the camera. But You need ODIS Online and a knowledge how to do it. But still - if You want replace 3Q/5Q cameras to 2Q0 is a perfect solution. And for most of people it will be just easier to change the camera instead of "patching" unit.
  2. You can change to mine camera or I can update it remotely if You have ODIS interface. But from my point of view it will be easier a lot just to "patch" camera on bench and then change it.
  3. I have two cameras 2Q0 where I installed a patch to activate all SWAP functions - including TRAFFIC SING RECOGNITION. So all You have to do is replace the camera and remove CP (eventually do some basic codings). 2Q0 980 653 H:11 SW:1027 2Q0 980 653 D H:16 SW:1401 If You are interested - contact me 😁
  4. MIBsolution is dead now. Do You have it locally?
  5. MST_EU_SK_PQ_P0353T will be great. Could You send it to me?
  6. Can anyone share MST2_EU_SK_PQ_P0369T firmware? Or just MST2_EU_SK_PQ_P03xxT?
  7. I want to improve my DCC settings - from 3 position to slider in Superb 2020. But whatever I do I cannot change it to slider. What have I done: Flashed DCC. From 5Q0907376B to 5Q0907376C. Updated DCC parameters to Arteon parameters. (I'v used original parameters from VCP library - maybe this will be cause of the issue. Maybe not all Arteons have slider?) Changed parameters in FPA Editor: Uploaded it to the gateway. Reset unit. But still looks like this: Do I need to change something more in FPA Editor? Or should I try with other dataset for DCC module? *It looks like parameters for gateway are working - because I can change other settings - for example dynamic lights, sport diff... @Frankenfurter @ApertureS @langers2k - maybe You could help.
  8. Hello, When I had connected phone via Android Auto or Car Play I cannot see name of song on virtual cluster - only "Apple Car Play" On my previous car - also in MQB platform this feature works - so I think it can be done. Anyone know it related to the coding/adaptation/software version? Maybe someone with VC and MIB2 STD can share adaptations and codings from 5F and 17?
  9. @langers2k - after flashing the gateway it was needed to parametrising, CP removal or SWAP/FEC input?
  10. Hi, I'm looking for new Superb. Yesterday I was driving MY2017 2.0 TDI - manual. And one thing is strange for me. - Car has a blind spot assist, but there is no rear traffic alert. This is normal conifg? Seller told me that RCTA was there before, but dissapered few months ago. And there is my question - there is a way to coding RCTA when Blind Spot is installed and works? Maybe You have instruction for this coding? I only found this: A5: Byte 11, Bit 1 (SWA) 76: "Rear cross traffic": installed (Byte 3 Bit 1 enabled) 5F: Adaptions: Car Functions BAP: SWA_0x1A active, DAtabus extended, Car Function Gen2 menu display lane assistand active, lane asisstant over threshold high activated 44: Nothing needed 3C: Should be more or less self explaning, without any data this (sample is 04 C0 02) 19: Enable 3C in Gateway, nothing else 17: Byte 11, Bit 3 active 03: Byte 29, Bit 7 active 5F are the 4 adaptions i mentioned. They are not 1 on 1 as they are described, but you will find them. 44 has no info about side assist, so nothing to do here This is for Passat 2016 and I would like to compare this instruction with others.
  11. I did it It works just like you said - I changed rear front light to B47 or B48 PIN. Footwell light is supported by B50 pin - diming from dashboard, turn ON/OFF...
  12. I have VCP and I tried to move rear fog lamp to pin B48 or B47 it works, but I don't have this pins in this BCM. So I will change it in the near future. For now I connect rear fog lamp to the front. So rear are turning on with front fog lights. Thanks for your help. By the way - VAG helper doesn't show each pins - for example it doesn't show front fog light. Do You know any better program or solution for this platform?
  13. But B50 is already taken by rear fog light, and when I turn on the footwell light in MFA, this rear fog lamp is lightning instead footwell light.
  14. Hi, I want to mount footwell light in Yeti from 2012. I already have mounted lights and harness. Now I need to plug this into BCM module. And there is a problem. PIN B50 is already taken. In octavia 2 prelift it was B7 PIN, but it didn't work in this case. BCM: 1K0 937 086 R Anyone know which pin I should use?
  15. Hi, I have MIB ST2 5L0035200A SW: 0133 I'm looking for 0138 SW for this unit. Anyone can help?
  16. Polish is very hard, and I think a lot of Polish people don't speak perfectly - so keep calm and learn polish If You have a question about it - just ask. VCP isn't friendly software but it can done other things than VCDS
  17. Few days ago I was mounting camera in Octavia III. In my instruction was mistake - they changed the pin in the blue connector. The third cable was ground - I mounted It near fuse box. And VCDS: 5F - Coding: Byte 19 Bit 04 But You will find it by name RVC or rear view camera. In nr 10 module You select wchich version of camera do You have. I think: Byte 02 Bit 4-5
  18. Hi, my friend still asking me about turning on signal indicator as DRL - something like US Style. Skoda Superb 2018. Below I put adaptation channel of 09 module. Maybe someone have the list with "leuchte" adaptation or already have done something like this? I think I need to copy leuchte3 adaptation: ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize G116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 <b> minimize </b> ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 27 ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 100 ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 Parking light right ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 <b>Daytime running lamps </b> ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 not active ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 <b> Blinken rechts aktiv (beide Phasen) </b> to Leuchte 1: ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 minimize ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 127 ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 33 - LED-Modul Blinkleuchten ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 Daytime running lights ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 Blinken rechts aktiv (beide phasen) ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active Am I right? I can upload a full adaptation channel if it will be helpful. 09 Adaptation.xlsx
  19. Hi, I just created a account. I have Skoda Yeti MY 2012 2.0TDI 170HP 4x4 and Superb MY 2016 2.0TDI - 150HP. I would like to exchange experiences with VCDS and VCP, and of course I invite you for a beer in Wrocław
