Everything posted by brsk
Update my car from 0156 to 0306
Hi, finally found a way to update sw. Thank you guys. I bought S3 month ago with this firmware (see attachments). In mib-helper I found it's the latest fw. Am I right? So there is no newer fw for my car? Thank you.
VCDS options on Superb III
Can you share instructions in vcds please?
so there is no way to unfold mirrors after ignition? / not after unlock car?
Hi, any way to unfold mirrors after ignition starts? Had S3 2017 and there it worked fine. I have S3 2020 now and mirrors unfold immediately after car is unlocked. Thank you
Scratched gearbox - how to replace it?
Thank you guys. I teied to seqrch but found guides how to replace whole gearbox only. Btw I have this one:
Hello, bought Superb 3 Sportline but there is really scratched gearbox. I already bought new one. Any video guide how to replace it please? Thank you a lot.
Hey guys, news to disable start/stop in my S3 2017. I know about voltage method but don't want to use it because of warning about high consumption usage showing in infotainment. Can you tell me other working way to disable S/S? Friend has disabled S/S with some other method and it works fine.
OBD 11
Ultimate = no credits required
- Memory module for Start-Stop button
2016 Superb L&K - What can OBDELEVEN do for me?
@CJJE Agree. Just for info, there is really poor support in obdeleven forums. I checked that and there are a lot od topics without replies.
Available coding/adaptation mods
Hi, possible to deactivate start/stop? Vcds / obdeleven Thank you
unfold mirrors after start ignition?
I dont want tu manual fold mirrors. In superb if I lock car, mirrors fold. If I unlock, nothing happens. Unfold is active after start ignition. Want this feature in kodiaq too.
Hello, mirrors unfold everytime I unlock kodiaq. Any way to unfold mirrors after start ignition? Maybe Via obdeleven/vcds? Kodiaq 2020. Can anybody write steps to do that? Thank you.
Change speed scale to 280km/h ?
Hello, how can I change speed scale to 280km/h via OBDeleven/VCDS? Check the video in 00:14 Thank you
Superb 3 - power consumption is high
Hope you're right and warning about high power consumption will disappear. Today I ordered battery Exide Start-Stop AGM 12V 70Ah 760A EK700 so in next days will be replaced for OEM. And coded of course.
So problem is still here. If dissapears after 20-30km. Don't know why it shows. Any idea please? Maybe it's because of bad battery? Today I ordered new battery - Exide AGM 12V 70Ah 760A EK700.
btw Start/Stop I followed this guide Go to Module 19 (Can Gateway) Adaption Go to Kanaal: Start_stop_voltage_limit change to 12.1V (standard is 7.6V) But I enabled it back already as I wrote in the first post.
can't edit first post. year of car is 2017. Superb 3 2.0 TDI, 140kW, L&K.
Hello, think I have a big problem. I had HEX-V2 + VCDS loaned from my good friend. Did some codings: - enable stripes with DLR - enable rear lights with DLR - disable beep while opening trunk with button inside the car - enable offroad display - disable start/stop For some days Columbus 3 shows me "power consumption is high". Ok, I found it's because of disable start/stop, so I enabled it. Start/stop is working for me now but information about power consumption still shows me in Columbus 3. I leave a car in about 6PM (after come to home from work). Carista shows me battery charge level 70%. Next morning (about 7.20 AM) carista shows me 55%. There is about 5C temperature outside at night. At the morning and at the everning carista shows me Battery voltage 14,7V (car is running). Will be very thankful if somebody helps me fix that. I think that problems started after my "coding". Followed only guides here on briskoda.net forums. Thank you very much.
Columbus Map Update 2022 (MIB1/2 HIGH)
Updated today, works perfect. Thank you
How to update software?
@CJJEthink you're right. Thank you for info.
Hello, just for my information. Is possible to download and update software/firmware via VCDS? Or it's possible in car service only?
Superb3 2017 - panorama - open/close with key?
Hello, is possible to code opening/closing panorama with the key? If I hold unlock button, all windows open. If I hold lock button, windows close. What about panorama? Is it possible? Thank you
Glass roof cracked
Same here. Went to authorized servise, they accepted a claim. In next days service will replace that part for free.
