Everything posted by raz2
Problem with comfort can bus
i had the instrument cluster removed on a skoda fabia 2 2010 and now i have a comfort can bus lost communication error in the can gateway and whe nthe ignition is tuned off nothig works on the instrument cluster
I need help with bcm unit from a 2011 skoda fabia 2 1.2 tsi
i want to power this up the bcm and connect to it using vcdss and also make it work with an instrument cluster. The only wire i have found is ground wich is a brown wire. The can bus and the k-line diagnostics wire are on the white plug. Does anybody have a pinout for it?
climatronic problem fabia 2 2010
some time ago i posted a thread about climatornic pinout as it wouldnt turn on no matter what. anyways i took the car to a mechanic said he climatronic is broken replaced and still same issue. it does turn on but fan dosent work ac dosent work almost nothing works. code is 5J0 907 044 C. Im wondering if someone has a wiring diagram for power and fan and other things. also i found a pinout on a site but its for older climatronic with three plugs the plugs on mine has only two plugs C and B
pinout needed for climatronic
- i need help with bsg unit from a 2002 fabia
yes i managed t odo that but i also want to connect the ecu- i need help with bsg unit from a 2002 fabia
i did but i didint find anything- i need help with bsg unit from a 2002 fabia
a so there is alos this cna bus on ecu( i think this might connecxtx to cluster) . And the pins at bsg for cluster are 2 and 5- i need help with bsg unit from a 2002 fabia
yeah but when i connect thenm like that the cluster fraks out- i need help with bsg unit from a 2002 fabia
no i have pins 2 and 3 that go to the ecu. THats the can bus for ecu- i need help with bsg unit from a 2002 fabia
no i want it to connect to cluster. First it need to go thru can gateway that is integrated in bsg unnit above clutch pedal then from the unit in goes in the cluster yes i have the wake up pin connected the can for cluster is working but for tyhe ecu is dead for some reason- i need help with bsg unit from a 2002 fabia
okay so when i connect the pins to the pins on the 2 and 3 pins on bsg nothing happenes ( and on those pins on the bsg there is no voltage) any idea? shoould be can bus voltage- i need help with bsg unit from a 2002 fabia
right now im trying to connnect the ecu to the gateway- i need help with bsg unit from a 2002 fabia
i know them already- i need help with bsg unit from a 2002 fabia
yes but i already figured iut the other one. Also i want to connect the ecu to the unit but the ecu has 3 can busses and i yhink i need the power train can but i dont have the pin (if it helps its a magneti mareli 036 906 034 BL )- i need help with bsg unit from a 2002 fabia
thanks- i need help with bsg unit from a 2002 fabia
thanks a lot. I already connected it to the cluster and powered it up but thats all i could do since there is little to nothing information on that unit(even a full pinout will help if you have one)- i need help with bsg unit from a 2002 fabia
so basically i mean the unit above the clutch pedal yes and i want to try to conenct to it using vcds ( i only have the module on bench) and im asking if i need can bus to connect to it or k-line if yes what pin would it be- i need help with bsg unit from a 2002 fabia
i want to connect to the bsg unit using vcds but i dont know if i need k-line or can bus. Also i want to connect the ecu to the bsg that has the integrated can gateway but the can bus wires for the gateway are dead, i cheked them with a multimeter and theyre 0 volt(im wonderig if there are other power pins for the gateway)- Does anyone have pinout of skoda fabia / polo 9n magneti marelli ecu ?
i dont think it shows the ecu- Does anyone have pinout of skoda fabia / polo 9n magneti marelli ecu ?
im looking to connect some senzors and the throttle to have some fun with the ecu- is there an analog wire for the fuel volume?
i cant seem to find the wire for the fuel volume, in another post a made some time ago i saw that the fuel and speedo is sent via analog. The serial thing is 6Y1 919 880 C B41- how do i trigger the washer fluid deflict light
yes- how do i trigger the washer fluid deflict light
it was an elegance vejicle so it had this function- how do i trigger the washer fluid deflict light
i know th ewire of the light but i dont seem to get it to trigger - i need help with bsg unit from a 2002 fabia
