Everything posted by superbuser35
VCDS options on Superb III
Do I understand correctly that this "power consumption too high" text is okay and it does not drain battery ? Or start-stop coding can be done without this "error" ?
I need help Recently bought new battery for my Superb 2018 and also asked do disable start/stop. After it was disabled, infotainment screen tells me "power consumption too high" - Is this okay and there is no power consumption or the coding was wrong and the battery running out ? Now, when I press start/stop button, then this "power consumption too high" text disappears...To I miss something ?
- 2018 Engine Emission Light
Superb 3 - power consumption is high
Did the message went away after battery replacement ? I have the same error. I bought a new battery Exide EK720 72 Ah 760A. I had it installed by a workshop + disabled Start/Stop
I guess were talking this item: 04L131113P - Weird is that I cant find any topic or video about Škoda Superb AdBlue urea injector problem or Škoda at all...Would be nice to read or watch video Does anybody have it to share ? Was there any software released when this 15733/P20EE came to be a trouble ?
Skoda Superb Combi 2.0 TDI 4x4 140kw L&K Business Edition - 2018
Updated infotainment: MHI2_ER_SKG13_P4518 1240 --> MHI2_ER_SKG13_P4526 1440
I guess not, only cold air was a little bit warm. Now it's very fine
Time-to-time, when scanning with OBDEleven I get NOx error: P20EE00 - SCR NOx Catalyst Efficiency Below Threshold Bank 1 Catalyst 1 Intermittent No dash warning and car driver normally. My question is - where to begin to solve this error ?
In the meantime, the weather was getting so summery that, sitting inside, you wanted to blow a little cooler air. To my surprise, it was lukewarm. The machine uses a newer type of substance, R-1234YF. The whole process took 45 minutes on the device, 0.460 kg of refrigerant was loaded and the bill was €95. The majority of places charge at least €120. The agency charges €185 for the same work.
- S3 owners - electric tailgate / hatch closing from inside
Hello! I have Superb 2018 L&K and recently, when I went to local workshop to adapt new battery, thought that maybe they can activate inside boot closing too. They tried with VCP, but failed. I don't know, how they tried exactly, but can someone share me info, where to start to succeed ? Should I control first something in car or how can I be sure that it can be done ?
Superb MK3: Changed OEM battery Varta 7P0915105 68Ah 380A to EXIDE EK720 72 Ah 760 A Disabled Start-Stop
The machine has been ticking so far on the OEM battery. Battery Varta 7P0915105 68Ah 380A. On the minus terminal of the battery, information that the production date is December 2018 However, I decided to change the battery and chose EXIDE EK720 72 Ah 760 A During the purchase, I investigated whether it is possible to get a battery whose production time is not very far. The code on the new battery was E811-339, so now I needed to understand, when the battery was manufactured. Exide made changes in reading the year of manufacture of the battery to 2021, and you have to look at the last three numbers, which is 339 at the moment, which means: first number 3 = year of production, i.e. 2023 39 = March Basically I got a battery that had just stepped off the line The battery was changed today and also deactivated start-stop.
infotainment update
- infotainment update
- Skoda Superb Combi 2.0 TDI 4x4 140kw L&K Business Edition - 2018
Okay...I hope now is the last problem solved 05.04.23 - During a cold start, the machine tended to cough and revs jupmped. Diagnostics were performed and the glow plug control relay was replaced, OEM: 04L 907 282 B 02.04.23 - I succumbed to the temptation and finally bought OBD Eleven - so that I could check the machine with my own hands if it seems a little sour. I have played with it a bit and I would say that the 60€ is worth it- Superb MK3 2018 cold start and revs jumping
Wen to local workshop yesterday and they changed glow plug control unit 04L 907 282 B. Going to wait until tomorrow morning and do cold start. Fingers crossed.- Superb MK3 2018 cold start and revs jumping
Today, when started Superb it work fine about 1 minute and then revs started to jump. The situation normalizes after few minutes past (I guess then the motor is warm ?) What to expect and is someone have been same situation. Car is 2018 L&K, 4x4 L&K On ordinary maintenance, they also scanned car for errors and on invoice there is info "EGR valve random errors on memory" - but then I didnt noticed any abnormal behavior until now... My car topic:- Skoda Superb Combi 2.0 TDI 4x4 140kw L&K Business Edition - 2018
Oh damn...On cold start, Superb started act weird and revs jumping + vibration all over the car. Done video about the current situation. It ends about few minutes. On ordinary maintenance in march, they also scanned car for errors and on invoice there is info "EGR valve random errors on memory" - but then I didnt noticed any abnormal behavior until now... What to expect ?
