Everything posted by ncsknc
Citigo aircon direction knob is not working. Always blowing in the face
Now the rear windscreen liquid is sprayed when I engage it under the car near the front passenger side when I engage it. Car is too low to go underneath with my big body 😔
It was a pain to get to but I fixed it. a physical rod connected from the knob to the actuator which turn the air flow up down and face. pretty simple and manual system , looks like to got knocked out by the previous owner trying to change the radio system.
Thanks!
Thanks! Going in this evening.
The previous owner has indeed changed everything by themselves to this Sony on the picture. I am having trouble finding a good guide or a video to remove this radio and the aircon control to reach to the back and check the conditions of the connections. do you happen to have a guide please?
This knob on the right to redirect to wind screen and foot well is not working. Always directing air at face level. also is there a way to check if the demister button is working? I believe the demister is only for the rear isn’t it? I ask because the button lights up with no effect. Also the rear windscreen liquid is not coming out. Hearing motor sound though. ergh.
Easy Dash Cam Installation
whats the name of this unit please? Stock?
Skoda service history check request - Does any one have access to erWin Skoda please?
Sent PM 🤗
Hey thanks. It’s 10 years and at 63700 miles. my last visit they convinced me that the belt is deteriorating showing me a old rubber flaking on google images. 😆
I can PM my VIN to check the service history. Looking for cambelt replacement among other things. CAT N car.
ABS Fault code - VCDS - How to fix this please?
Perfect thanks! Will experiment this weekend.
Thanks! Does the code mean anything in narrowing down to which door? The vehicle has 5 doors including boot. Still searching how to fix it.
quite unsure. It's listed under the ABS fault then again in the top of the report no error is recorded. Fault priority 6 means something from my googling. Ross-Tech: VCDS Tour - Fault Codes Number Meaning 0 Undefined by manufacturer. 1 The fault has a strong influence on drivability, immediate stop is required. 2 The fault requires an immediate service appointment. 3 The fault doesn't require an immediate service appointment, but it should be corrected with the next service appointment. 4 The fault recommends an action to be taken, otherwise drivability might be affected. 5 The fault has no influence on drivability. 6 The fault has a long term influence on drivability. 7 The fault has an influence on the comfort functions, but doesn't influence the car's drivability. 8 General Note
Skoda Citigo, Airbag light stays on. Could someone near London help me diagnose and reset for me please? Wires were loose underneath the seat, replugged all of them! Does Ancel VD700 reset the code?
Turns out the aigbag cables were unplugged under driver seat. WTF. I stupidly thought the light means airbag feature is fully functional when bought the car. I wonder if the seller tried to cheat me by giving me a lemon, as they didn't know how to fix and Garage quoted 65 to diagnose and 400 to fix. Anyways, plugged in cables, a redditor helped me out with a VCDS and cleared the error. It's gone. Status says OK on the VCDS report. Good to know the airbag is fully functional now. Fantastic!
2019 spark plugs replacement interval ?
Piggybacking on this, did you manage to change it yourself? Any guides please? Recommended tools? How would one know that the spark plug needs changing? All looks okay since we bought it at 63k miles.
How to fix this error with ABS please? No fault lights on the dash. Few questions, Does my car have ABS? Status: OK 0000 it says in the top but Fault is present says in the bottom, Priority says 6, a minor one? Fault frequency says 2 and reset counter says 4. Does that mean in the last 4 times it has been reset, it came up again twice? 0193 Door Contact switch, not sure what it mean or how it is related with ABS. Any insight would be helpful!
Hey thanks. you are right! Amazon it can be reset. Manufacture website doesn’t mention anything!
My engine noise is a bit raspy. Is this normal for a Citigo? It's a Skoda Citigo SE GreenTech.
Thanks!
The mudflaps are a good idea! Our car is very filthy from the previous owner. I don't knwn how to clean it now. !
Thanks! 1SO-863-831-A I can see you have quite a few mods to your car done! Where do you get them may i ask? This is £50 it says in ebay. 1S0863831A for sale | eBay Will it just straight fit Citigo even though it says VW up? do you source them somewhere cheaper? I was told the susuki is a 1 L engine. Not sure how to upload my engine noise. Do you happen to have one from yours? I think yours is newer. Ours is 2013, 63 plate Greentech with stop/start.
Not sure how else to describe it. Recently driven a Susuki Swift and it was quiter and smooth in the cabin. Mine is Kar Karr Kaarr... hoarse... lol.. Can I make it quiter? Does engine oil make it an issue?
Need help with connecting a wire to the side indicator holder.
This thing is an work of art! Not a single dust spec was inside the connector and it's a decade old! Push in, press the plastic bit and pull out. Simple and effective. Was able to get it out, thanks for your help Pete!
Good idea! I noticed it says VW and some numbers number. Found a connector. Looks like I have to remove a the plastic bit that goes over the bulb holder (male and female connector) Mine is stuck! Not budging one bit! Golf Wiring Harness Repair Kit Fits VW T5 Polo OE 1J0 973 722 A S1 Febi 171901 4054224719015 | eBay
