Everything posted by xess
Battery parasitic drain issues
Any updates on this topic?
Help, 2.0 tdi ea288 injectors.
Hello again, maybe some one can give me some hints on where to look at. Problem: when starting cold engine 2.0tdi ea288 150km mileage, injectors in D mode start to show rich fuel (deviation)+1 / +2, when in P(Park) no problems 0.1-0.3. After engine heats up no more problems. I can feel it by vibrations. Thanks.
Superb mk3 Strut Mount recomendations
Cant find any bilsteins in my region.
Maybe someone knows which manufacturer makes OE strut mounts for VW group / Skoda? Looking for replacement, can't decide which brand to go for, SKF, FEBI, MEYLE, OE. Share some experience please 🙏
Tyre specs 94h / 98V
I know the difference between 2.5 and 2.3 bar, much more softer, just thinking how much stiffness XL will give.. I already ride deflected tyres so my guess XL would be stiffer. With same pressure.
94 is 200kg over the rating, so should be ok. I'm living in Latvia, roads are crap and XL tyres are hard as hell. I don't plan going crazy on curbs, so reinforced sidewall is not needed.
I dont want anything above spec, as they all go XL, very harsh ride on our "Europe" standard roads.
Superb 2018 4x4 2.0tdi 140kw sedan
Hello, does anyone know where I can get legitimate information about tyre specs from manufacturer, as I cannot find it anywhere on the car. I want to fit 215 55 r17 94H, some dealers say it's 98V, some 94h. But those come with index XL, and I don't want hard tyres. If i put wrong tyres on, there is possibility that I can not get my MOT.
Some errors I would like to get rid of.
Hello again. So I have superb 2018 mk3 4x4 l&k. Dashboard no basic settings B201000 Driver assistance Camera malfunction C110400 Let me know what is needed to locate problem, I do have obdeleven so I can make report. So far I have not noticed anything that would worry me using car. Last owner might have done some changes in obdeleven / odis / vcds - start stop turned off (B201000). Also could anyone give me some contacts of good specialist in coding, who could look at this remotely as I don't have anyone in my area.
DCC Slider adjustment option mod
My only worry is how they did it for Skoda, and how big the difference is compared to VW.
First of all thanks to everyone involved here, and doing amazing job. For everyone who attempts to do this, make sure you find a person who have done this before as it requires high skills in this platform. In my area I could not find anyone. I could not find any DIY for dumb people, if there are any they are incomplete. It took 10 hours for start and 15 minutes for guy who did the magic. Impressions from dcc, now it works like in advertisement, day and night difference. Reduces road noises from suspension and tyres, as it's eats small imperfections better and stiffens up on bigger stuff. Front caliper rattling gone (90%), flywheel and gearbox feels much better without being tossed around all the time. Suspension is not bottomed out at all! Feels like bmw / Tesla/ toyota mix. This is only for people who drives in bad road conditions, when driving on good roads I did not have any of those problems (not in my country). I recommend doing this to everyone who have option(correct gateway, dcc module) to do so. I would even go for module swap if that can be done. The only problem is finding person who can do this, because nobody wants to be bothered by someone with 1000 stupid questions for the time it takes and money it costs. PS Does anyone knows how are the Skoda superb mk4 dcc acting?
Dataset version for gateway.
Does anyone knows where to find dataset version for gateway module. Trying to make edited dataset, but can't find my version
FL_5Q0907376C__0130.xml
Can anyone send me edited data set for FL_5Q0907376C__0130.xml ? Cannot open the file in fpa editor for skoda superb MK3 4x4 2.0tdi for dcc slider
Boot lid open on its own.
So there you go, I don't think it is a key knob, because you have to press it with certain amount of force, not so easy. And it is only happening when near the car. And if there would be sound then I could relate it to key knob. So far I think it's some kind of circuit problem.
But how do you explain that it was activated with keyfob if it makes sound, when activated by key.
Hello, maybe someone have figured out whats wrong with boot lid. It only opens when I'm near the car, opening / closing trunk. Once when washing the car. I do not have virtual pedal for opening. When this happen there is no beeping sound. So I suspect it is not the key fob, as it does make sound. Either wiring or one of the buttons outside / inside. Any thought's? Also maybe someone can drop a manual on how to remove boot lid covers, I plan on looking at the wires and everything else. Thank you!
- Dcc springs
Dcc springs
Okay, so I found this to be the closest match for the front 1mm longer and 3mm thicker from Opel. RA1300
Dcc springs
For the rear, I'm guessing this is the closest match by length 3Q0511115M 365mm vs 366mm, the only difference is the outer diameter +6mm. Do I need anything else in order for 3Q0511115M to fit correctly?
Dcc springs
@CarlstonThank you, could you suggest one weight range up for front also?
Dcc springs
The problem is that for the same code it gives me different height options. Front 318 or 322mm. Rear 360mm 365mm 358mm, and different diameter.
Dcc springs
Could not edit my last post, so at the moment I'm considering to put original springs, to see if its going to make any difference, also check front struts, as the car has 135 000km mileage. After i could try a bit harder springs if that is going to help with bottoming out on bad roads. I like how soft is the car, i dont like the bottoming part
Dcc springs
Okay, so far this is what i get from catalog with my vin number. Front 318mm (KYB) or 322mm (Eibach)both 12.5mm thickness 5Q0 411 105 Back 365mm (11.8 thickness)KYB, 358mm (12.3mm thickness)Magnum, 360mm (11.75 thickness) Monroe 3Q0 511 115 AK I have liftback (hatchback) saloon. Everyone calls it differently, non towbar model. TMBCJ9NP3J7579286
Thank you for your work. I'm also going for this, can't stand the bottoming out on bad surface roads, though I love how soft it is on medium quality roads.
