radoszczak
Everything posted by radoszczak
  1. Could someone explain why we should update in a row with several fw ? Is it there some kind of factory reason ? I'm going to update directly from 1310 to 1800. I found an answer that's fine.
  2. Thank you. I'll ask my dealer in PL about it.
  3. I have read here about wireless smartlink on MIB3 with 1800 SW, someone wrote that is a way to activate it with skoda pack that can be purchase via online store. Does anyone has completed this with success ? (I own skoda scala 2021 with wired smartlink that works, I don't have wifi/WLAN options on menu). Thank you in advance.
  4. Update succes. Ignition on, engine off, charger connected. Estimated time of update is 20 minutes via 8 gb fat32 pendrive.
  5. I have question about size of update. My bolero mib1 doesn't have NAV function. I have download 0490 update but it's size is about 5 GB after unpack from 7z/zip. Have I downloaded accurate version ? In my case I need only to update main firmware without maps etc. Thank you in advance.
  6. Hello, is there known improvements with update 0421 to 0490 ? I have O3 with bolero infotainment. Sometimes it is lagging when I use mp3 audio from sd card. Anyone knows that update to 0490 could fix this problem ?
  7. Is there known issues with firmware update from 1310 directly to 1800 ? I have all for now - fw on usb c native stick, and power suply charger. I'm planning to update car this weekend. Any advices ?
  8. True. I miss that 469 is missing. Please tell me more what is native usb stick ? I'm using a usb-c adapter to micro-sd card. Is it will be ok to use it to update firmware, or better way will be use an adaptor usb-c to normal usb and put an ordinary usb stick to it ?
  9. Thanks for answer. Is charger nessecery to do an update ? Is engine running isn't enough to power up battery and keep right voltage in car ?
  10. All here as far I know. https://disk.yandex.ru/d/1V1uBTc8ssc3zA
  11. Hello, I have read all topic, and I need confirm that what I will try to do is correct way to update my mib3. So I have skoda scala from 2021 with bolero on fw 1310. I have known s23 issue with AA. I need to to an update. Simple question: should I update first to 1790, and then to 1800, or I need to try all chronological verisions in a row update like 1760, 1790, 1798, and finnaly 1800 ? I have download 1790 and 1800 form mib-helper. Thank you in advance.
