Everything posted by radoszczak
Backup battery - Service Life Critical
Could you re-upload ?
Thank you. Is left plastic bezel that is shown after door open, is on plastic clips or screws ?
I have scala 2021 and the same issue
Do you have more pics of dissasemle of plastics to get to the eCall module ?
Thank you for your response. It May help but for now I will just use car without battery replacement. As far I know capacity of li-ion based batteries can last even 10 years with 70-80%. Is it possible to reset battery stats from 50% to 100% it seems car ecu aproximate battery Health only based of lifespan. If ecu reads capasity and voltage ,errors should be pernament, and not able to reset. There is shadow of idea that red nofitication shows after about 5 years and force user to visit workshop to replace battery or just reset stats. In My country yearly car control needs no red indicators. I just looking for answer, is it safe to ride with 5 y Old battery for next years. I dont want to replace good battery for new one.
Do you know what exactly should I dissassemble to replace battery ? As far I know eCall module is real deep behind the fuses on the left side near lights switch. Is there clips or screws to take of ? Is there some kind of manual that could help with battery replacement ?
Hi, I had used this method and reset battery stats. Does car ECU measure battery stats like capacity and voltage, or this battery life meter is only based on time that has elapsed since car manufacture year ? I had bought new battery but it is quite hard to dissasemble the eCall module. After crash eCall unit can use main car battery to make a call ? It seems to be stupid is only power of eCall module is this litte backup battery. Anyone now more about it ?
Stop Start disable
Hi, you only need to remove button bezel and place cable into small space under it.
Software Update available for Bolero?
What was said before: 469 is update to 741+742 - the last official firmware for your hardware.
Poor ground at trunk back light bulbs liftback
Hello, I'm trying fix my issue that is bearly light in trunk when lid is open. What I check till now: I have changes trunk lid lock to new one, connectors 3pin are fine, and I see open trunk info at MaxiDot I have checked connector at left C-pillar, there Is black/brown cable that has ground when lid is open, and ground disapear when lid is closed When I disconnected 3pin wire from lock at lid, I still have about 9-10V at trunk lights connectors When I put healthy ground to the bulb, it lights normal Resistance beetwen healthy ground and faulty ground at lid light bulb connector Is about 20 kOhm I have checked that ground signal from trunk lock do the ECU is providing only MaxiDot info What should I check to find faulty place where ground cable could be damaged ? Ground cable from trunk lid connector goes to the major wiring in trunk but It seems to be not the same ground line that is disconnected by swith in trunk lid lock Im sorry for my language, If it is something hard to undestand, please ask. Thanks for your time.
Cześć, poniżej link do strony z opisem możliwych FW U Ciebie powinno pójść do wersji 742. https://www.drive2.ru/l/650934799095051499/
It is in the topic but as I remember folders data and meta should be in folder named by fw, not in root of drive.
To large storage. Try 4 gb.
I did not notice better sound after update from fw1310 to fw1800. Did it only because of android auto issue at samsung s23ultra.
Have you read this topis ? All answers are in it.
You need 1800 fw to fix android auto problem. Link is attached in this topic.
I would try to update directly to 1800. Yours fw version seems to be somwhere between 1310 and 1760, as they are available on the Internet.
Front Wishbones bushes separated
For all those that will change it in the future. Parts mentioned above fits.
Hello, Im going to change wishbones in my mk3 2013/2014 octavia. 1.4 tsi 140 ps chpa. So I typed these below. Could someone confirm that is right choice for my car ? It seems to be difference after 2014 in this car ? Wishbones lemfoeder 38633 01 and 38634 01 Ball joints (swing arm pin) 29999 02/LMI + 29998 02/LMI In ETKA i have found two wishbones types 5Q0 407 151 P/L and 5Q0 407 152 P/L someone know that are major differences beetween those parts ?
Hi. Have you read whole topic? Android auto issue with samsung can be resolved only with fw1800.
Hi, I have upload for you fw469 fw741 and fw742. Please be aware that all updates you will do on your own risk, even risk of brick unit. First question you need to ask yourself is: do I really need an update ? Good luck. https://easyupload.io/xlhs1d
Coolant real temperature
Do I Have termostat integrated in coolant pump in my chpa ?
Since car pruchase in 2022, I have not replace water pump. Timing belt was changed at 160 kkm, but pump stays becouse of no leaks and mechanic said it should run as well. Now I have 196kkm on dash, still no leaks. I think pupm works well, instead I could be observing to hot cooling fluid right ? Gauge never gets higer then 90 deg.
Stop Start disable
I had replace cable to a new one, now works as it should be. Of course seller won't send money back, but alixxxx do the job and refund all cost.
Hi, today was another test, below: Starts with 18*C deg inside car temp (not like yesterday 22) 1. Cold start at 4*C deg. 2. Slow drive becouse of traffic, about 20-30 kmph, disntance 3-4 km 3. After 5 km I had 90*C deg on dash gauge 4. Oil 50*C deg, after 5-6 km 5. After leave town, normal road at 80-90 kmph 6. After 10 km I had about 78-81 *C deg oil temp Seems to be ok ?
