PrinceLC
Everything posted by PrinceLC
  1. Si puoi aggiornare senza dubbi. Fatto anche io
  2. Better install first 1941 but other confirmed that it's working directly from 18.. Firmware. H56 is ok I have H56 also
  3. Also I like it now how it is you can choose how it looks now with the icons on the bottom or on the side. Other good thing is you have now fullscreen with Fermata Auto for YouTube 👍😜
  4. The interface of AA is now how it is mentioned by Google. Skoda did an update to the resolution for AA to match it. This is how Google want AA to display on an Car Display.
  5. Yes had the app updates too. But your map and KESSY Problem I don't have it. Only sometimes when it's wet the sensor on the driver door don't work properly.
  6. Never had this bugs by updating manually
  7. The thing with AA is that Google say that the display must have a certain resolution and VAG did it so you have the option now to move the icons to the bottom and vice versa. This is how Google want it.
  8. Also this album cover problem and VC seems only on Apple side. On Android side all fine.
  9. It's an EU version so it fits. The firmware checks before updating.
  10. Ah ok never tested with guest account
  11. It's not a bug when AA is set as a widget than the window is smaller delete the AA widget and AA is on the complete screen
  12. New Skoda owner too had this two updates as well but no faults or issues. This is the third update that I did manually. But I have read that a lot of user have issues after updating also the firmware over the air strange behaviour
  13. Updated with running engine as well no issues all fine. And no faults like other here I don't know what's going wrong then.
  14. In AA settings you can change it to vertical again. The alert button is visible in my case
  15. So you can install 1985 without problems when you know how
  16. Also you can directly upgrade from 1941 this is confirmed, but when you have 1803 or 1806 it's better to go to 1941 firstly Ok so install first 1941 than 1985
  17. Yes but go to System information and tell me what is written there so I can tell you if you can direct upgrade or not
  18. Tell me the version number 17.. 18.. or 19..
  19. Ah ok also the command in German are ok will test in English
