Everything posted by Holderness88
Skoda Octavia vRS TDI 2014 swap
Not sure if this is the place but looking to swap my Octavia vRS MK3 2014 , 99,600 miles will go up as daily car for work, Had timing belt and water pump done at 72k miles, Recently had rear and front discs and pads, X2 drop links also have 4 new glow plugs tonne fitted and a fuel filter also have ordered X2 ball joints as I'm very particular with parts on my car. I'm looking for the Skoda Octavia vRS 2.0 TSI petrol version Message me or what's app me on 07716858572
Intermittent starting issue
Issue apparently solved was a split line to the fuel filter now been replaced seems to have sorted it
Standard VRS MK3 Wheels and Colours?
Hi guys I have originally alloys and my cars silver not sure to repair alloys black with having silver car ?
AFS issue - any ideas?!
OBD Reader questions?
Hey update fixed my AFS bending light error and another code went to do with low voltage I'll show the part I change on my drive This part front left sensors green arm was solid seized
I was told if it starts in cold weather without issues then won't be glow plugs I'll have to get a multimeter out on them
TDI the 181 bhp
Cheers Dave
Ah yeah I see what you mean, I'll have to have a ask about or take a drive to yours haha
My diagnostic machine should work though surely it's up to date and Its bidirectional or do you mean specifically for Skodas ?
Unfortunately not no I presume OBDeleven is the Bluetooth one to your phone ?
Is they any way of me testing the temp sensor ? And is this the coolant temperature sensor as funny enough my temp gauge goes up fast and stays in the middle
Hi, so thought I'd ask the forum this when I go to work at 6am in the morning my car starts fine no issues even when cold I then drive 6 miles to work and leave it there till 4pm when I leave work and try start it it cranks over few times then starts and kicks out smoke , then drives and starts ok after that , then drive 6 miles home and leave over night till 6am an no starting issue only when I seem to leave work
Glow plug replacement
Hi all, how do I find out if my Octavia has a pressure sensor in or not as Skoda took my reg and he said that he can't see it with a pressure sensor , this was the same at gsf parts Skoda Octavia vRS MK3 2014 2ltr 181 bhp
Skoda Octavia MK3 workshop manual 2013-2018
Hello guys not sure if I can post this however I purchased workshop manual for Skoda Octavia MK3 covers dsg and manual gearbox and alot more if you require the manual I'm more then happy to send it via email 👍
Morning just remembered I bought a detailed pdf file for Skoda Octavias MK3 workshop manual if you need it I can email you it
I have a launch x431 pro elite and that doesn't show any DTC other then low pressure , headlight range control and low voltage I think
Is they any way to test this to save me replacing this if it isn't broken
Not sure what's causing the odd struggle start up he said starter motor was fine , possibly glow plugs ?
Morning, just been to Halfords and had battery tested it's at 63% kicking out 400 amps and battery says should kick out 600 and something amps maybe this is what's causing my odd start up when it's left in the sun
Yeah will do thank you , in the meantime the leveling arm I have doesnt come with the metal arm that connects the top of the green lever , I'm wondering if mine will be on to reuse as I'm not sure what I'm to look for when reusing the arm that connects to the top end of the green lever
Just looked at the terms of sale and nothing on there stating approved used
How would I know if the vehicle was approved used to confirm this
Not sure where I'd stand in regards to the goods act would I return the car and receive full refund ? I paid around £7800
