Everything posted by thomaser07
Scala steering wheel slightly off-center — anyone else noticed this?
I’ve noticed that the steering wheel on my Scala sits slightly to the right when driving straight. It’s been like this almost since I bought the car — it had around 4,000 km on it at the time. I’m wondering if anyone else has experienced the same thing? Could this just be a common quirk of the model, or should I have the wheel alignment checked? Thanks in advance for any input!
Clutch creaking when hot
A friend of mine had the same problem and went to an independent garage, where they replaced the clutch slave cylinder. The noise stopped. But it might have been enough just to lubricate it. A friend of mine who rebuilds gearboxes had also suggested this to me earlier, but I haven’t gotten around to visiting him yet.
Kamiq 1.5 TSI (manual) noise from clutch pedal
I went in service. three times... everyone says something different. One says it's like this. The other says it's a clutch mechanism, the third says it's the junction of the working cylinder and the pressure fork..
nothing?
any news?
:/ From 0km?
anybody? :)
jesus :/ When you shift between 2500-3000, there's a clearly noticeable resonance, and it’s like I can faintly hear something as well. Is it the same for you?
thanks! I went to the local authorized service center, they listened to the noise and said they think it's the clutch assembly plates rattling. It probably won't fall apart. No warranty replacement. It's a disgusting business policy. The Hungarian importer dismissed me saying it's normal operational noise, there's nothing wrong...
Please let me know if it changes.
what did garage tell you? it's normal? nothing problem?
thank you .How many km does your car have?
I’m sure it’s caused by the heat, because I have to drive a few kilometers before it starts making this sound, and I can even feel the noise through the pedal — or I don’t even know how to explain it. There’s no such noise when it’s cold. So yours is noisy too, but only when warm? Can you feel it through the pedal as well? If you have time, could you make a video of it?
Medley! same as mine?
my scala has a same noise. i think it is the lower clucth cylinder.. is the problme solved?
The noise is clearly coming from the lower slave cylinder. It probably needs some grease at the end where it pushes the push rod.
Scala 1.0 tsi, 81 kW, 6 speed manual slight vibration of the clutch pedal
It’s true. I noticed that I can feel it on the clutch pedal between 2500 and 3000 RPM. Sometimes I even seem to hear something quietly. But above 3000 RPM, there’s no sensation at all.
is this problem solved?
1.0 TSI manual: difficult to pull away smoothly
It is worth asking if there is an ECU update available for the car.
Oh sorry. It’s public now. Check it!
I have a problem. When it warms up, there is a crackling sound when the clutch is pressed and released. It is not there when it is cold.. Does anybody have? https://youtube.com/shorts/egegjeF7WSA?feature=share
hmm. interesting I have another problem. When it warms up, there is a crackling sound when the clutch is pressed and released. It is not there when it is cold.. Does anybody have? https://youtube.com/shorts/egegjeF7WSA?feature=share
I have a Scala 2023. and I have the same issues. is this problem solved? some people said to me There were several cylinder mods. Last time in 2024.11.01 Supposedly this can solve it.
