Hi all, just joined the forum today as part of trying to figure out why the rear washer on our new (to us) 2016 Fabia estate SE doesn't work. It's a manual with 1.2 TSI petrol engine. The rear wiper motor works, and both the washer and wipers at the front work fine. When pressing the stalk all the way back, there's no sound whatsoever from the pump. With the stalk in the normal on position, the wiper goes constantly instead of intermittently. Based on comments and experience elsewhere I am thinking the stalk may be corroded inside etc. Fuse 22 was blown but replacing that hasn't helped. However as part of messing about with it I've noticed that if I push the stalk back to the washer position with the ignition turned off, the airbag lights on the dash light up, there's a warning beep and the MFD says 'Start system faulty! Workshop'. This goes away when I release the stalk. There's no issue at all with the starting system in normal use, and I've not come across any other electrical issues so far apart from a dead interior reading light. The car has a normal key turn start, not keyless or button start. Has anyone else come across this? Is it likely to be a sign of a wider electrical issue, such as a faulty BCM?
