Redboy
Everything posted by Redboy
  1. Good luck with the group action. In the unlikely event that you can prove anything is wrong with Lane Assist, Skoda is notoriously the last of the VAG group to take responsibility for well-documented design faults. Lane Assist is is just part of the car’s overall safety aids. Until all UK roads are well marked I can’t see how we can have autonomous driving. The safest thing we as drivers can do is, drive to the prevailing conditions, take breaks to avoid nodding off at the wheel and declare known medical conditions.
  2. Lincolnshire is flat unfortunately, round the rural bends in this part of the world, usually B roads, it's often hedgerows, trees, tractors, horses, spiced up with grain and mud to endanger motorcyclists. You can read the road signs, see the church spires and telegraph poles to anticipate the bends, but not see the tractor and trailer pulling out just around the blind part of the corner.
  3. All very interesting for track use. The standard car is good enough for everyday use. Point to point journeys on Britains busy and battered roads now take longer than 30 years ago...if you don't want endorsements on your licence.
  4. Rather than turbos being weak, even if run as standard, do you have still to look after the turbo any more? By that I mean letting it idle after a long run rather than shutting off immediately? I used to religiously let both my standard MkII and especially the stage 1 MkIII idle on the drive. I confess I didn’t do that with my Golf and switch off my 272 without idling, the rationale being that I drive slowly onto the estate and reverse slowly back onto the drive, so I hope temps have dropped a bit.
  5. I checked the oil properly today ie on flat ground 5 mins after turning off with the oil temp at 90 +C and was a bit surprised to find it was not too far off the bottom of the hatched area after 4400 miles, the last 2000 miles in free flowing rural and motorway miles. I say surprised as my mapped 220 VRS didn’t use a drop in 4 years. 250ml of Castrol SAE 5W-30 VW 504-507 returned it to over 1/2 way up the hatched area. I checked the oil type with a dealership, which stated that the models built from Nov 19 use 0W-30 oil. As mine was built in Jul 19 model it is on long-life service interval using 5W-30. According to the dealer when it’s serviced in October, it will be filled up with 0W-30. He did say if I topped up with the wrong oil, (yes I know it’s just oil!) I presume he means not 5W-30, i.e. 0W - 30 then the warranty would be invalidated if it blew up. It won’t blow up. I presume the 0W-30 oil is VW 508 00.
  6. Just to get away from Politics and viruses, this photo will make all the 50+ guys smile with memories. I rescued this from an old car club years ago. It hangs on my garage wall. There are a lot of the cars that I saw coming through my dad’s hands, when he ran a second hand car business in the 1970’s. If you check out the Simca plugs, you’ll see why I laugh when people ask on this forum if 110 Bhp is enough for a Fabia. Although today’s cars are much faster, I bet you’d be hard pushed to do Bristol to Weymouth quicker nowadays, due to the amount of traffic, than our old Sunbeam Rapier or S type Jag 3.8... which I hated as I wanted a new Cortina 2.0 GXL!! 😄with a blue light like my friends dad had ...( who was a Fire Brigade chief) . My dad had 6 old Jags all in working order, in the early 80’s parked at our house. Here’s a 420 with chrome wire wheels, tinted windows and a E-type engine and the XJ6 4.2 reg that I got to drive as a 19 year old on leave from Germany. The most exotic one I got to drive on my leaves back in the UK was a NSU RO 80 again, mine for a week or so. The best handling was an Alfa 2.0 GTV.
  7. No water squirting out 2 days ago as I was returning home. Sat on drive and suddenly worked. Not used again until today....didn't work. Got home. Water bottle full, only ever use the VAG approved liquid, definitely no sound of a washer pump motor whirring. Checked as far as I could see, there were no loose connections. Tried to check if it was a fuse, the only suitable fuse I could find in the handback pages 228-231, was 19 (windscreen wiper) under the bonnet. Removed, shiny with no oxidisation, so refitted it and pushed all the other fuses to check they were correctly seated. Pulled and pushed the washer stalk, whirring noise and washer fluid pumped out of the front and rear screen jets. 1. Has anybody had a similar experience with the MkIII Octy, if so what was the solution. (Please no stories of 1970's Cortinas etc ) 2. Is fuse 19 the correct one, I didn't see any mention of a dedicated washer pump fuse. 3. Is it easy to access and remove the water bottle via the left front inner wing panel? I think I might have to change /check the pump if this continues to happen. Thanks
