Posts
30 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by Pimmen
Bluetooth not working on Bolero
Pimmen replied to dimacherno's topic in Skoda Superb Mk II (2008-2015)
I have to chime in as well, have a 2010 superb with bolero unit, I have Bluetooth in it and it worked when I got it used several years ago, but at some point it just stopped working, and now I'm thinking about really getting it to work again. I have tried unplugging, I have checked fuses (I think I have managed to check everything that has to do with phone or Bluetooth) Is my next option to search for a replacement BT unit? I have found one locally here in sweden but it's very pricey for a used part, the ones that are cheaper on eBay etcetera look to be in very poor condition and older than my car is. -
I hear you, but as I wrote, I have checked each and every "pin" in the outlet, and only the pins where the corresponding lights are working is giving me 12V when for example I brake or use the turn indicators, so I'm positive that the problem is there.
Don't know, it's factory and the year is 2010 if that is any help.
I have had problems with my trailer lights for some time and finally today I tried to find out where the problem is. And I have used my multimeter and found out that the problem must be somewhere in the wiring, the lights are working, the fuse is fine since some lights work. I only get a faultcode on the left side of the trailer, where do the wires go FROM where I plug in my trailer?
What size bolts for my front seats?
Pimmen replied to Pimmen's topic in Skoda Superb Mk II (2008-2015)
It's two straps that attach to the back of the chair and to the floorloops im about to install or around the front seat backrest -
My kid already rides in the back, just don't want to wrap the attachments around the backrest of the the seat, since that limits the adjustability. Thanks for the your input. -
I have a 2010 superb with electric seats, I'm about to install "loops" for a babyseat and they go where the rails for the seat is installed so I need to remove these, install the loops and screw them back in. What size bolt do I need to buy? I only have smaller ones. These are not regular torx right?
The phone pairs and everything works except in the dash display Sent from my Nexus 6P using Tapatalk
Leaving/coming home stopped working.
The indicators flash as they are supposed to do. Still not working, no error codes at all when I had the car at the shop to replace a broken window motor. Any more suggestions? Sent from my Nexus 6P using Tapatalk -
Battery got replaced less than a year ago, so I dont think so. Sent from my Nexus 6 using Tapatalk -
Yea, will try that probably. Sent from my Nexus 6 using Tapatalk -
Superb 2010. Have worked since day one until a couple weeks ago, have tried changing the time setting, deactivating both settings for coming/leaving home, returned light settings to stock,nothing helps. Light switch set to AUTO, and have always been since I got the car. Coming home - car door is shut & locked, then the lights stay on for a short while & then go off. Leaving home - when I press the fob to open the doors, the headlamps come on. Sent from my Nexus 6 using Tapatalk
Powered Tailgate operates intermitently
Pimmen replied to richard999's topic in Skoda Superb Mk II (2008-2015)
Hopefully I can have mine replaced and looked after on wstr/extended warranty from the dealer I got it. -
When I try to open my electronic boot it clicks and doesn't start moving, if i open it a bit manualy and click the button again it opens 2/3 of the way, and when i close it it does go all the way but error beeps at the end. But everything locks up etcetera. What can I possibly do to cure this? Skoda superb II (2010) estate.
When I close it I get the error tone but it locks and everything, when I open it up it unlocks but doesn't lift, and if I maneuver it manually it goes up if I press the button after that, but only two thirds of the way up. What can be the issue?
Awesome, easiest way to remove it? Sent from my Nexus 5 using Tapatalk
Some of the diodes on my superb estate high break light don't light up, can i replace only the bad diodes or do I have to replace the whole thing? Sent from my Nexus 5 using Tapatalk
Oh sorry, really new to this forum, it's an 2010 superb.
I haven't yet looked in the manual for this, and don't really have the car here now either. Bought led parking lights/position lights. And going to install them in the car.
Remove interior trim from doors and dash
My girlfriend made the fronts, looked awesome. I'm located in sweden, and have looked for options. I will let her have a go at it first. Sent from my Nexus 7 using Tapatalk -
So even if I can get the door panel of the trim still isn't removable? -
I managed to remove the bits from the dash/around the stereo. But when I try to pry the panel on the front doors they seem more stuck then the other parts did. From which end do I start to bend them loose? Sent from my Nexus 7 using Tapatalk
Difference between columbus and borelo
Pimmen replied to Pimmen's topic in Skoda Octavia Mk II (2004 - 2013)
will it be even MORE better sounding with sound system with 12 speakers?
