Everything posted by oldstan
Yeti 1.2 TSI (110) DSG (2016 (66) SE L) - Skoda approved warranty cover for clutch packs or other issues
The only reason I used the word "Recall" was it was the word the dealer used. See below. But it won't be keeping anyone awake tonight, I'm sure. 😀
Quick reply to Goob (and, by the way, welcome to the forum) ....... it's not entirely relevant to your enquiry but I would just say I've had a 1.2 Yeti DSG from new (bought in 2011) and remain very pleased with it. I'm very well aware of the DSG problems in the past and am hopeful that they have been overcome on more recent models. Mine developed clutch judder within warranty and (after a bit of resistance) Skoda agreed to fix it. They fitted a new clutch in November 2013 and I believe they did a software update at the same time. That fixed the problem. They then carried out a DSG recall in October 2014 at 15,000 miles which included changing the transmission oil to mineral oil. I drive it very carefully and with much sympathy for the transmission and the DSG has been pretty much faultless since then with just a tiny hint of judder every now and again - but very insignificant in the scheme of things. It has now done a mere 38,000 miles. The (main dealer) garage has been OK and serviced the car up until a couple years ago but it now goes to a trusted local indie. The indie has said he wouldn't attempt any repairs to the DSG and would recommend a more specialist transmission repairer if needed. I'm very fond of the car and if it were still made would buy a new one (with a DSG box) and take out the longest VAG extended warranty available .... but they don't, so I can't. I'll keep it until something happens to force a change and at that time I would probably buy a Toyota, Honda or Kia on the basis that they are probably the most sensible/reliable bet. The Yaris Cross appeals and has a 10 year warranty if serviced at a Toyota dealer. Lots of people dismiss the dry clutch DSG and speak ill of them - some have owned one and some haven't. I find it easy enough to drive and don't find it troublesome, even in traffic but will admit there are occasional circumstances when it can be caught out and (rarely) it disconnects the drive if it senses the clutch is slipping unduly ... for example any tricky or extended manoeuvring on a steep hill could cause the drive to disconnect as it thinks it's stressing the clutch plates and cuts the drive to prevent it causing damage. You have to stop and re-start: not the end of the world but some might find it unacceptable. Not a lot more to add but ask questions if you wish.
"SERVICE NOW" warning on display.
Having quickly looked throught the conversations above I didn't see the instructions using the trip reset button and knowing my luck I'd have got it wrong and finished up having to get it sorted anyway. The joy of my bloke up the road is you can pop in and bend his ear and know you won't get taken for a metaphorical ride. He did that little bit of wizardry for nothing and I collected my fish and chip supper at the same time so it was no hardship. 😀
Took it to the fella up the road. He got a gadget out of a drawer and plugged it in and 30 seconds later I was on my way. Sorted.
Ooopps. Posted in error
Just been up to the independant garage where it's been serviced for the past couple of years and he asked me to pop back when he's quiet and has space in the garage and he'll plug the laptop in and sort it. Ta.
It was last serviced in April just gone. It's done now by a local, trusted, independent who I've used for years. He did it last year and the year before that too. Prior to that it was done at the nearest VW/Skoda main dealer. I'll pop up to the local fella and ask him to prevent it from doing it (assuming it's something he CAN do.
When I turn it on it now bongs and the above advisory shows on the mulyi function display. I've had the car from new for the past 11 years - mileage 38,000 - and it's not done this before. It gets an annual service. I can't be the first person this has happened to? ........
Skoda Yeti - Removing the Glove Box
I'm just adding a last post to this thread. I started another post ..... click here to see the other topic .... ...... and received advice and fixed the problem by eventually getting cover off the push button release catch and removing the whole glove box and greasing the mechanism and adding a stronger spring the operate the two sliders that hold the lid shut.
Just this minute succeeded. Whilst trying to find the G Spot to release the tab I used a large screwdriver to exert a little push on the cover in between the cover and the main part of the dash so that if and when I did find the release tab the cover would spring over - and it did - with a satisfying little "snap" sound. Added some grease to all the sliding surfaces plus I found a little spring in the toolbox, trimmed it down to size and added it to the existing spring to give the two sliders a bit more oomph. The original spring looks quite weak given it has to operate two sliders and overcome the friction of the mating surfaces etc. Both protruding prongs now catch their respective holes and the lid now closes (and holds) 100 times better than it did. Much obliged.
Boot light goes out after after a short while.
Definitely no torch on mine, as predicted. But I confess to having a little bit of a torch fetish and there's no shortage of portable light within the car. My most recent purchases are a Fenix LD30 (which is a proper little cracker) plus a couple of real cheapie Lithium Ion 18650 lights from Amazon. Really cheap but, considering the price remarkably well made and handsomely bright with strobe and SOS. I keep the SOS lights handy in case I ever broke down in a vulnerable position and could use them to warn oncoming traffic (I'm thinking smart motorways where a breakdown in a live lane would be frightening and even if the light wasn't strictly legal I think I would take my day in court if nicked for it). Just been and had the battery tested with a meter at the garage - all appears correct. Thanks for responses.
There's only one boot light and it's on the laeft as you look in the boot and it's not removeable (without a screwdriver to lever it out). The battery is on charge as we speak and when I open the boot the light stays on all the time the boot lid is up. I'll still get the battery checked tomorrow. If it needs changing then now seems as good a time as any. But three and a half years life for a car battery will be a record for me.
On the left. I don't think I was aware there was one on the right, but I could be wrong. I also wasn't aware of the possibility that the light might be romoveable and/or rechargeable ... but I'll have a look. Ta.
UPDATE. I Googled again but this time just put Skoda rather than Yeti and found theis ............. And indeed, when I started the car it stayed on (and was quite a bit brighter too) so it obviously thought the battery wasn't performing at full tilt. I'll charge it. I just looked and the battery (Varta Blue Dynamic D24) is three years and four months old. The warranty is 4 years. I'll take the car to my usual indie and get it tested. Varta say they'll replace it if it's shown to be defective.
I've only had the car ten years, so I have the perfect excuse for not being familiar with it 😏 As per the title - it goes out after less than ten seconds. If I close the boot and re open it the same thing happens. Perhaps it's always done it but I've not noticed. Ta.
Thank you for the response. I'll look again but am not confident I'll find the tab given how long I was looking last time. I had a mirror up there and shone a torch light on to it and just couldn't see a "tab" that looked like it was gonna release the cover. But I'll try .... and am grateful for your advice.
I've seen a previous, quite old, thread about this and did, earlier today, add to it with my own further query but it doesn't seem to have manifested itself in such a manner that people would see it so I've taken the liberty of starting it up again here. Any thoughts from anyone who has succeeded in getting the glove box catch off will be gratefully received. Ta.
Is there anyone here who has actually taken the cover off the glove box lid catch ? It simply says stick a small screwdriver up behind the cover (there is actually a small cutout in the cover) and release the tab. Well I just spent ages with a small mirror and a torch looking for the tab. And, obviously enough, I cant see what they're talking about. There's even a drawing of it but it doesn't seem to relate to what I can see. Anyone?
Any recommendations for auto electrician in the South West (Devon) area.
Note to moderator .... I've duplicated this in the Yeti forum intending to remove it from here but now realise I can't remove it and would imagine it contravenes regs to have the same post in two places at once .... could you possibly take it down please?
Any recommendations for auto electrician in the South West (Devon) area please?
I posted the request (below) on one of the other Briskoda forums for a few days with no replies so I'm not holding my breath here, but it's worth a go. There have been several threads about owners ( of various models) who have had trouble with LEDs failing in their dash/display binnacle - I'm trying to say the LEDs that illuminate the speedo, rev counter fuel gauge needles. There's one called TotalTronics in Wareham, Dorset who looks more than capable of repairing the failed LED but he's two hours there and two hours back and I want whoever does it to remove the binnacle and replace it rather than me remove it and send it somewhere. The threads I read seem to suggest a specialist is called for rather than ..... a non specialist .... i.e. one who can strip components down rather than just diagnose and replace a given unit. Someone who comes recommended and has known experience in what I'm on about would be good. Ta.
Replacement Battery
I'm no expert (at anything) but my take on the battery matter is:- When the car won't start it goes from being ... a useful, convenient and sometimes enjoyable thing to have at your disposal .... to being ... a useless pile of metal taking up space on your driveway. And we all know the battery will fail at the least convenient time (which often happens to be at the first cold snap of the winter). I have the luxury of a small, not very valuable, second car which could be used if the Yeti were to stop working for any reason and having that second car gives me peace of mind but I still have an earnest desire to keep both of them in a fit state to fire up when needed. So I'm reasonably happy to spend money on a new battery providing I've had, say, five years out of it. And to that end I've changed the batteries on both cars before either have shown serious intentions to fail ... but I reckon I can tell when a battery isn't at its best and is coming to the end of it's days. I have a little battery powered thingy called a Draper Computer Memory Saver which plugs into the ciggy lighter and keeps the settings intact whilst I disconnect and reconnect the old/new battery. It works perfectly but you can't, easily, get the same thing any more but similar things are available. So that makes installing a new battery foolproof and means I can easily order a battery online at the best price I can see (combined with buying from a company I trust from previous experience) and fit it at home at my convenience. The two companies I've used most recently and would recommend are Tayna and Battery Megastore. The most recent battery for the Yeti was a Varta D24 (027) and cost me £67 from Battery Megastore in October 2018. Mine is not a Stop Start and is a 1.2 petrol DSG. The only other thing I would mention is that I bought a further 'belt and braces' gadget recently - it was called an Overland 18000mah 5volt /12 volt /19volt Power Bank and Jump Starter and was sold by a company called Mobile Solar Chargers. I keep one in each car and make sure it's charged up every six months. It takes the place of a set of jump cables and it got my neighbour out of trouble recently and he was suitably impressed and vowed to buy one for himself. I'm so impressed I'll leave a link (which the mods will remove if it's considered inappropriate) https://www.mobilesolarchargers.co.uk/shop/details/overland-waterproof-car-jump-starter Here ends the first lesson.
SGS gas struts
Have to say I have a pair of struts from SGS fitted to my Hyundai i10 - fitted April 2019 - and they're fine. EDIT .... just had a look and mine are marked Nitro Lift.
New water pump and belt.
Re. the above ... The pump is on the offside (front right). I can confirm the leak was gradual and minor. There's a small drilled hole at the bottom of the water pump and the staining around the hole indicated that it had been dripping for a while and only became noticeable when I spotted a small pool of liquid on the garage floor. The bottom hose had become soft and de-laminated at the point underneath the water pump. The garage initially put a new clip on the hose thinking the leak was from the hose itself but it turned out to be the pump. My car is ten years old so I have no real cause for complaint.
