Connect additional reversing lights
When you say the unused reversing light, is that not the fog light !
Dumb Questions from a Newby!
If you leave the Key in the car and shut the doors, nothing If you have the hill hold on, it won't do any thing as that only does anything when driving( its not a hand brake) but you do have a hand brake, but you don't need to apply it as when you stop the engine it will come on automatically, and also when you are setting off you don't need to take the hand brake off as it will disengage as you set off
- Skoda Octavia YouTube Channel
Dash-Cam connectivity with USB C socket adjacent to rear view mirror.
Just to put a spanner in the works, If you are using just a single camera you might be fine, but if you are thinking of both front and rear I don't think the USB supplies enough power for both. But to be honest connecting to the fuse box is not hard and its then just a matter of running the cable under the trim
2023 vrs towbar
OK Dave, if you were a bit closer I would recommend East Yorkshire Retrofit as I have had some work done by them and the did a perfect job fitting a reverse camera, but would have liked the electric retracting towbar, but I guess the company in Poole will do the job right (hopefully at the right price) for you, Good luck
2023 vrs towbar
Wez Morrell Manchester Wez Morrell Manchester 0161 430 7591 I had mine done by this company I know it not near but give them a ring and see what they say ?
2023 vrs towbar
Where abouts are you in the country ?
2023 vrs towbar
First thing to check is what your car can tow, a lot have zero Kg limit, and that would stop you towing, you can check on the sticker on the drivers door slam (thats where mine is) and then find a decent towbar fitter that can code as well as fitting the bar, I had a removable one fitted to my VRS estate and had it coded and if it is coded correctly you wont have any problems with reversing, as when you plug in it detects the trailer(Caravan) and switches off the system for reversing !
Front assist alarm - MOT FAIL?
make sure the radar sensor and windscreen are clean
Kessy locking keys in car
I know this should not happen but why would you leave your Kessy keyfob in the car, I have never done that, even with the old keyfobs. I put the key fobs in my pocket so when I get out so does the fob
Locking fuel cap
Why go you want a Lockable fuel cap, when there is one all ready on the car !
Brake pad change with EPB
No
- Battery life on pre facelift cars
You don't need any device to do the front, but you need a wind back tool like OBD11 etc to wind the piston in to change the pads
