- Unintended vehicle movement causing collision
- Superb mk2 2.0ltr pd140 - Whistling sound on revs
Kodiaq petrol.... Cambelts
As I say - your choice - but I've not yet seen any evidence of early failures at all. I generally keep my cars a long time (usually well over 100k miles - the last two have been 132k and 113k). I'm sure you are aware but a cambelt change on a TSI Petrol with ACT will not be far short of £1000 given the specialist nature of the kit required to re-time the cams, and other parts of the world haven't been reporting early failures within VAG's latest changed recommendation. On the other hand - what I have seen is reports of issues AFTER such cambelts have been changed... But as I noted - each to their own.
You both make fair comment and that's your choice as it's your car. However personal experience, and that of the rest of the world that has had similar regimes (the UK was the only country that didn't follow the VAG guidance for Thier technicians) suggests they can last much longer than 4 years or 100k miles and you would therefore be wasting money changing them. But as I said... Your car, your choice
They are belts but classed as 'lifetime' so are reinforced and stronger than normal as well as the engines having oval shaped cam gears to reduce load on them. From memory the service requirements are 240,000km / 150,000mls and then only 'inspect'.
- Tyres and grip
Anyone with more than one car ?
Had three since 2007 and four for a while but all different... As per signature with the Civic being the fourth for a quite a while after I got the Swift...
the truth about electric cars
I'm sure youve said previously you had it in the Zoe or Scenic...
That'll be one person in this thread... 🤣
Surely it doesn't really matter either way if you treat zero as zero... Which is what most sensible people do
In general no... But what it is doing is reducing spend on other things that involve travel and is therefore indirectly reducing car use.
Armrest too short?
Rather than replace it you could just get a new leather cover for it to go over the top
Interesting... Of the two I think I'd go for the Nissan to avoid the 'ooh look at me trendy' stigma attached to the Renault...
I notice the Nissan version of the Renault 5 is getting better reviews than the 5 on everything except 'looks'... It does look very similar but has better aerodynamics and range and more options and tech by all accounts.
Skoda Kodiak 4 and 2 wheel drive difference in specs?
TBH I'd be changing insurer if they can't even get vehicle details correct from a registration plate or VIN
