handyandy
Everything posted by handyandy
  1. Thanks for the information pab567. I am going to try re-flashing the firmware first with the latest version from varooom. If I do need to replace the touchscreen is that something you can supply? How easy is it to replace? Do I need any special tools?
  2. Thanks very much for that. Just a last question... Do I just copy that file to a blank SD card or do I have to unzip it with something and just put the resultant files on a blank SD card? Does the SD card need a name?
  3. That would be great thanks. I suppose if I'm going to do it, I should use the update if possible.
  4. I have seen various posts saying that they have updated firmware etc. Where do they get the firmware software from? I can't find any good links! I think (not totally sure) I need MH12_ER_SKG11_P2104_1 but don't know if there is an update or I need more. Help PLEASE!
  5. My ignition press button does not operate easily; I sometimes have to repeatedly stab at it to work. How easy is it to remove this and clean it out as some forum members suggest?
  6. Thanks, varoom, the photos from the engineering meu are attached. But not sure I could update because when on the update screen none of the touchscreen buttons work! Do you have firmware for this unit?
  7. Hi, Help please someone! A few weeks ago, we were driving along and the Columbus unit in my Mk3 superb suddenly started changing stations by itself... then it started a loud on/off beeping. I stopped turned off the ignition waited a couple of minutes and retried. It seemed ok but had lost all the programmed radio stations. I managed to rescan and get these back with some difficulty because the rescan wouldn't respond to my touching the screen. I have now noticed that if the parking sensors have been working you can't touch the X pad in the top RH corner to turn them off. They stay on till 15mph or so. Also, if I set the Satnav some items don't work by touching and when it displays 3 routes to choose from you have to rapidly touch the one you want for it to register! Also, I think the starter button doesn't work as it did you really have to press on the brake pedal and stab at the button for the ignition to come on (or switch off). Everything seems to work ok but the various touchscreen buttons for radio, satnav, media and car settings don't work properly. On different sources the same area of touchscreen may or may not work? Can I get Skoda to reflash/correct the unit or is it a new one? Regards, Andy
  8. Think I have decided on the PS4. Quoted £160 each fitted which sounds pretty good to me!
  9. 23,000 and by no means worn out. The rubber on the side walls has 'aged and shows a fair degree of cracking. I would rather change them now and me get the benefit rather than sell the car with new(ish) tyres to someone else.
  10. Hi, The original fit Cinturato p7 tyres will soon need replacing. What do you guys recommend as a good replacement 235/40/19 tyre? I don't want any that are to noisy.
