Everything posted by Graham Butcher
the truth about electric cars
Although this car would not fit my personal needs, it does embody lots of the points I have long stated are completely unnecessary in so many new cars of both types of power trains, less reliance on touch screens, more actual buttons etc, less acceleration, smarter seating and lower costs as well as less tech that are just there because they can. Those 4 dots (leds) on the steering wheel are a great idea.
Yes, I'm aware of that thread, I started it and I drive and indeed it was about ICE cars as well as EVs, but the point of the video I linked to was about one particular insurance company and their attitude towards EVs, which I have zero experience of insurance in conjunction with EVs.
All I was doing was highlighting the various ways that you could be vulnerable, as EV cars are already packed full of extra technology than ICE cars are. My ageing TomTom after market sat nav keeps getting new tricks after each software update, none of which were ever even I suspect were envisaged when the model was first launched. Also to this effect, the more modern ICE cars also carry far more tech on board than, models say of 10 years ago. One of which is the digital mileometer to prevent car dealers turning back clocks, that data as more and more computing tech is introduced could be brought into play for PPM at some point in the future. But now, it most be a person who has limited knowledge of computers and electronics to completely dismiss these possibilities out of hand. I did say at the start of this debate, something along the lines of don't be lulled into a false sense of security over the possible measures that RR could introduce and with the combined facts that A/ EVs don't pay for fuel duty which is a massive revenue source for any government, B/ VED is not the same as for ICE, so again a net reduction in revenue raised, C/EVs are able, or at least some are, able to be accessed remotely, software updates over the air etc are perfectly possible, so logic says ideal candidates for the very first PPM system. This video, in case anyone missed it which clearly shows that some EV's can be accessed remotely courtesy of the mobile internet.
Ok, lets get back to the truth about electric cars, this video of an electric car/truck owner in Canada believes he has discovered why electric cars are being written off so easily. I'm an electric car owner/user, so I'm throwing this open to you lot who are, for consideration, what are your thoughts on this?
Car Park Fires, Transporters / Ships, any fires, any EV,s involved or not thread, were they the cause just there and so made fighting the fire harder.
You like to see the gory details, try this one for size then, so scary, no warning at all.
@wyx087 good grief, firstly, I never stated any county in my posts, but the fact that EON are using BPL shows it is possible for data to coexist on powerlines, thank you. Secondly, there is NO need any extra hardware installed in the AC charger or socket on the car for data to be dumped onto the power line. That hardware could be anywhere in the car and 2 wires attached to the circuitry anywhere, as long as there is nothing to block it's passage around the cars loom. The wiring in your house also does not require any extra hardware, the wiring is just a means of transporting a low voltage high, frequency signal which is also extremely low power, it's a conductor only. The data only requires hardware at the point of it being extracted from the local power supply. This could be a very small box located at the end of the street and can extract the signals for every house in your local neighbourhood as long as they are on the same power phase. No tin foil hats involved, its entirely possible and there are secret tests of loads of things going on right in front us every day that we are not aware of. That is how new ideas etc are tested to discover if they work or not before they even get mentioned in trade press etc.
Twist it whichever way you want, but you're both twisting what I said if you read it correctly.
No, you're wrong, I did not say grid lines, I said power lines and one of those articles I posted showed a diagram of that happening for a group of houses and the data went to another interface further down the line. So now you are now claiming that the article about EON doing just that with 200,000 houses is fictional, WTF? Wrong again, there is so often a world of difference between what they state and what actually happens. How do you know that secret trails are not being carried out? All it takes is a simple software change or are you also going to claim that modern cars don't keep records of miles driven in their ECU's. The info is there already; it only requires that memory location to be addressed, and there it is. Also, the sockets that I plug my Ethernet over power adaptors into are ordinary, standard sockets, so is the mains power cable; they do not need any extra hardware. That on an EV, could already be built into the car itself. In case you have not yet got the concept, I need 1 adaptor plugged into whichever socket I want to use as the feed, and 1 in each socket I wish to access the Ethernet from, so I have 5 more scattered around the house and input and output units are identical with 1 RJ45 socket on each that a cat 5 cable plugs into. The power circuit in the house is not modified, so broadband and other data can and do get carried on standard power cables/lines, deal with it. Your opinion because you cannot accept that there could be another side to things that you cannot see, open your mind. Would you jump over a wall without looking at what is on the other side first to see what you could be landing in/on?
I can understand where you're coming from with the above, the car in this video was converted from petrol to electric 4 years ago, 2021, and yet when I checked to see if the DVLA reflected that fact, back in 2023 after the Luton carpark fire when the diesel Range Rover was said to have started it, the DVLA still showed this as being a petrol powered car, 2 years after the conversion, here is the link to that original post I made at the time which includes the video and the DVLA records showing the Citroen as being petrol Car Park Fires, Transporters / Ships, any fires, any EV,s involved or not thread, were they the cause just there and so made fighting the fire harder. - Page 3 - Electric Vehicles - BRISKODA It's interesting how, at the time, everybody dismissed the idea that the Range Rover could have been converted to electric, but the records held at the DVLA showed it as diesel. Now, if the Citroen DS had been the cause of that fire, then the fire brigade would also have used the registration plate details to check with the DVLA, and their information would have shown it was petrol, which is clearly not true. Today DVLA have now got the correct details showing the car is electric??? Copy of DVLA current details for the car shown here. Strange how time can help to prove that theory could actually be correct after all, but as always, the armchair experts that are only too willing to accept the official reports must always be the correct ones, not the slightest doubt in their mind. I have always said that time will eventually show the truth. I also note the latest DVLA record shows that a new V5C was issued on 6th June 2025, so was that because the car has a new owner, they have just updated the records, or had the other owner only informed them of the modification?
@lol-lol I'm not going to disagree with any of that, RR has inherited the most appalling situation left by the last lot. It has all the hallmarks of being a well laid trap so they can spin it back against this government at the next GE to keep them out of power for many years to come. Politics is a dirty game played by self centred people many of which don't care about the country and all of its people.
I think you're right. Its interesting how people view things when they appear to have their feet firmly planted in of the affected segments of society. I love to get people's opinions on what could or could not be taking place in the budget, but there is one thing that we can all agree on, it will be those that can least afford to shoulder more responsibility for the nation's poor financial state that will proportionally feel the pain more than others.
When ignorance is bliss, then you must on cloud 9, I never said it was, I asked a question. But here is something that you might like to consider, I also never said that the data signals only travel via power lines, did I. Fact is that data can and does get distributed over power lines, I even make use of that technology in my house, instead of running cat 5 cables all over the house (mainly because SWMBO hates seeing cables) I have had my broadband intake positioned in a bedroom, and then taken the signal from the router up into the loft and down into what was my home office, into a Netgear switch, and then taken cables out of that to feed a A1 plotter, a printer, a scanner, 2 NAS units, 2 PCs and then onto another switch in a sons bedroom which splits it again to feed a smart TV, 3 game consoles, a PC and a wireless access point. Then I use PLC (Power Line Communication) to run the broadband down to another switch in the TV cabinet to feed a smart TV, Internet radio, smart Blu-ray player and a Free view recorder unit as well as another wireless access point. The same PLC also sends broadband round another son's bedroom because he hates wires, and that feeds a game consol, printer, and a PC along with a smart TV. PLC is also used to feed another wireless access point adjacent to the front door to provide an excellent, strong signal to my doorbell and door camera, so yes it can coexist alongside AC power, but there are, as you rightly said, certain things that it cannot get through. That said, I never said that travels all the way by power lines either, because it makes its way to a series of wireless stations, i.e, mobile phone stations etc for onward transmissions back to the suppliers datacentres where it is processed to provide billing for the customers. Here is something else you may like to consider, BPL (Broadband over Power Lines) which is useful in some areas and is ap parentally being used to provide smart meters to around 200,000 houses by EON, so you are not as correct as you thought and so that makes far less of tin foil hat wearer than you would attempt to paint me. "On 19 January 2018, E.ON, the German multinational electric utility company, serving about 48 million customers across several European countries, decided to use BPL in the low-voltage segment of their grid for communication with their smart metering devices. The utility chose Corinex as the provider for the initial two years of the deployment. The initial deployment was several ten thousand repeaters and headends, providing secure communication for meters at about 200,000 households. The utility selected Corinex GridValue energy management system, using the IBM Tivoli platform, to manage the network.[22]" How Broadband Over Powerlines Works | HowStuffWorks Broadband over power lines - Wikipedia there are many other references as well I know that you also like to say TLDNR, but sometimes you may and can learn something by reading.
If your paying £1k tax on your interest from your savings then that almost makes you into one of the fat cats doing tax evasion, well maybe not a real fat cat, but certainly a tubby cat (pun not intended) and maybe part of the reason why Rachel from accounts is scrabbling around looking for ways to plug the deficit that doesn't upset the elite.
True, but I have had company cars before, and the companies have reserved automatics for management only, plebs get manuals. Smaller cars have the front wheel well encroaching into the footwell so the pedals get squeezed together with far less space between the clutch and the transmission tunnel, meaning wide feet have problems in that area. When I had those cars, my sons either had not been born, or were just toddlers or small children; that's no longer true, they are my size, 6ft 4", and also have larger feet than most, hence the need for larger cars, as @lol-lol pointed out with the roof line also presenting less space in the rear in lots of cars. So, for some, it is only large cars, of any powerplant type, that will fit the bill for those who are not of average dimensions, which is what most cars are designed for.
Totally agree with what you said, but everything rolls downhill to those at the bottom of the food chain to make up the shortfall, i.e., those who already have the least resources. We need far fewer think tanks that lobby on behalf of funders, who are extremely wealthy and believe they deserve to keep more of their money than others can. We need politicians who are there for everyone, not just the elite.
Yes the front is fine on so many cars for me as well, as they are not manuals, as with size 15 and extra wide feet, the footwell on manuals simply is bleeding dangerous for me to dive safely, far too easy to foul the pedals, or press 2 at once with such large feet, another reason for me to need a larger car is right there.
Don't fall into the trap that EVs are hard to tax on a PPM basis; they aren't. I think you'll find that a data signal can be superimposed onto the power cables, isn't that how the information is transmitted from your smart meter back to your power supplier? When they installed it, they never installed any other cables, and smart meters work perfectly, whereas some people find it almost impossible to get a mobile signal! It matters not if you only charge your car from solar; the PPM is only charging you for using roads, so plugging your car into a charger is also connecting your car to the super data highway for data collection, as your car details, reg number, from which they can identify you, and the distance you have travelled. With a digital ID system, and your bank details also connected to it, they are already being checked for signs of extra income, i.e., a side hustle on eBay bringing in more than £1,000 a year. There is no way to escape the charge, which is also cheap to collect by direct debit. Big brother is watching us. We could all be sleep walking into a world like that painted in the novel, 1984. We are slowly being conditioned to that by being told how convenient these steps are for us, like withdrawing cash for digital money, but digital money can be manipulated by unscrupulous players.
The 3% is what you quoted in your post, I thought you was claiming that the 3% was how much fuel duty the EVs would add to the revenue. Which at £9.1 billion in 2025-6 would fetch an extra £273,000,000, very nice, thank you. The Renault 5 has done a good job of capturing the essense of the old model,
You appear to be in denial that this is even a possibility, yes, it might well be only 3% of the fuel sales currently (makes a mockery of the industry claim thought about EV's flying out the showrooms, which we all know is not true, currently, if it was, then there would not be any grants for them). But, this figure, unless there is a massive relaxation or reversal of the net-zero push, that figure will steadily increase, and the fuel duty will begin to decline at a bigger rate, and it will hit the poor government's ability to balance the books. They have to be looking at how they can recoup that lost income, and the answer is right there, in the car, all EVs are recording the miles driven, and I dare say even the route taken especially if they have sat nav built in. Data is already carried along power lines, the technology for that has been around for many years. With the now digital VED, and the network of cameras across the UK and police cars, have ANPR capabilities. The phasing out of cash been underway for some time, the introduction of the digital ID system which we are supposed to be getting, bank accounts being scrutinised by government bodies, and will be linked to your digital ID. Payment can be deducted direct from your bank account, and your bank account could also be frozen if they so wished, (apparently this is already being done in places like China and Vietnam, for example), also with so many EVs now having over the air software updates and even diagnostics done the same way, they could also if payment was not being made due to lack of funds what ever in your account, disable your car while your charging overnight at home. All of these things are for a vehicle that must be plugged in to refuel, are or could be, a real possibility. True with the ANPR cameras they could attempt to do similar with ICE vehicles, but they would need far more cameras for that. When you stop and look at it like that, the book by George Orwell 1984, could become a reality. So the moral here is, never say never, because it just might.
Multiple sources as is the norm just before a budget, surely you must have heard and read about it in many places by now, there always leaks?
I just heard a rumour that the budget is geared up towards EV's, to replace the fuel duty that you not paying, they are weighing up either PPM or, weight as they are of the opinion that an EV is actually heavier then the normal car, even SUV's as SUV's (as long as they are ICE) pay fuel duty. I think that the PPM would be based currently, solely on the miles driven rather than time of day or type of road. I said it before that it is thought that every time you plug in to charge, at home or anywhere else, you car is capable of reporting your current mileage automatically over the grid, but like I said, it is not yet confirmed, but may happen.
Glow Plug Control Module J179
Thought it would, so much cheaper than new glow plugs or pressure sensor.
What about this one then with an electric bus bursting into fire after a crash with a car, the batteries were exploding like fireworks going off and one passenger on the bus died in the fire.
@wyx087 I was looking at this document, and it certainly looks more complicated than the cooling for ICE, especially as the document states the danger of not keeping the battery pack at the optimal temperature, risks a dangerous thermal runaway event of the battery. EV Battery Cooling - How Does It Work? — Lectron EV
i see what you mean, but it is still only one system, the water flows straight from the block or jacket as you call it, into the head via waterways in the head gasket and the pump on modern cars is indeed normally mounted in the block/jacket at the front of the engine. But your garage took advantage of you with that £800 as on my Superb, the pump is recommended to be replaced at the same as replacing the cambelt which does require engine to be stripped down so the belt and pump come as a kit and that only cost me about £500 a couple of years ago at the main dealer. It is possible to replace the pump and thermostat without taking engine apart, but you do have to take quite a bit off to get access to it, this video shows it. I expect that is why the belt and pump are often at the same time because of the time taken to get access.
