G60 Flywheel and VR Clutch
I'm assuming I can do this upgrade on a 2002 VRS because it has a 5 speed box? Can someone just confirm for me please?
John
Sounds like the kit I've got for my 4x4 1.8T.
Check out Awesome Sarah, got mine from them.
I doubt anyone will be able to beat the price I can get the OE stuff for, about £230inc. But if they can I'm all ears !
The question you asked was "can it be done". :confused:
Yes is your answer. I've had it done to my 2003 vRS.
Its what i'm running on my MK2.
What difference does this make?
Yes I did your right, I was simply referring to the above comment on where to get it from. I was 99% sure it would be fine just wanted to double check. Thanks
It eliminates the troublesome (at times) dual mass flywheel. Nothing to go wrong with a single piece one! It'll take a fair bit more power also.
Its a fair bit lighter meaning the engine can spin up quicker.
Sorry to hijack but could the G60 be used in a pd130 diesel?
No, the PD 130 uses a 6 sped box and thus a larger flywheel and clutch.
Cheers Dude
