Park Shift Lock
On a 2004 model year (pertol) Octavia Automatic the car will turn on and start in Park or Neutral - but you cannot shift out of P or N with teh ignition on or engine started.
the display shows EPC (or similar) on the instruments.
Is this a micro switch adjustment and if so where is teh switch and how do you adjust?
thanks
Check/change the brake pedal switch.
Do the brakelights work?
Will check this today. more than likely this is the problem. thanks
