Leaky bits!
Got a bit of damp prob! Octy mk1 1.9 Tdi The bulkhead/scuttle keeps filling up with water, can't seem to find the drain holes... any ideae where they are, carpet was swimming the other day, all help /adice gratefully recieved!!
Skud 1
Holes go into the wings under the plastic panel at the bottom of the windscreen(usually blocked with leaves).Do a search on this forum and there are plenty of info about this problem.
It can help in the rear of the front wheel arches to take out a couple of the torx screws, and pull the liner toward the wheel a bit. Generally then you will be able to pull out a few hand fulls of composted leaves, followed by a load of a water. Rince through with a hose pipe or watercan from above - remove of the scuttle panel helps, but the buildup of weight from the water above might help, and thus save you from having to attack it from the top.
