Fabia Gearing ratios: vRS - 1.4 16v
Does anyone know how the overall gearing (mph/1000rpm) of a Fabia vRS differs from a 1.4 16v? Noticed from the Chris Longhurst Tyre Bible that when I get some 16" vRS wheels from a fellow Briskodian :) i will need to buy 215/40/16 tyres not the fitted 205/45/16 's to get the same rolling radius and a correct speedo reading :( .
ttfn Karl
very doubtful you would get a 215 in a furby arch.....
Very roughly, the gear ratios in my Fabia are this:-
1st - 6mph per 1000rpm
2nd - 11mph per 1000rpm
3rd - 17mph per 1000rpm
4th - 22mph per 1000 rpm
5th - 27mph per 1000rpm
6th - 32mph per 1000rpm
The gear ratio's are irrelevant, all you need to be concerned with is the rolling radius of the VRS alloys compared to your wheels, if the 2 are the same the speedo will remain accurate. What size are your current tyres?
205/45 16 will be the required tyre size same as the vRS
Its 86mm profile for the 215/40 vs 92mm for the 205/45
6mm difference in profile, less than a brand new tyre to a worn out one, I wouldnt worry.
So do i, one reason for the post to check if the vRS wheels/tyres a straight swap in both gearing and fit. Think 215's upper limit for a 6.5" rim, 205's seem to be about
Stimps (iirc) is running gen Fabia vRS wheels on his 1.4 16v and no problems on the original tyres.
6mm difference in profile' date=' less than a brand new tyre to a worn out one, I wouldnt worry.[/quote']
Thanks,
Tyre Bible said that using the vRS wheel/tyres @ 70 would show 72 on speedo, just being too precise in matching RR's.
ttfn Karl
