Help needed - drivers door problems
Hi all,
Please help! I have major problems with my drivers door on my 2001 Fabia. When you press the lock all doors button on the drivers door all doors lock but the drivers door will 'bounce' and immediately unlock itself. All other doors remain locked.
The central locking will not work by using the key in the drivers door. The drivers door will unlock and lock manually but it does not activate the central locking. The passenger door is fine.
I have noticed that the interior lights do not come on when you open the drivers door but do when you open the passenger door. The light at the bottom of the door card does not work on the drivers door - it isn't the bulb as I have checked that. All the fuses are fine.
Any ideas what could be wrong? Any help would be much appreciated.
Drivers door lock is f**ked:D
