Fabia vag connector socket location
Hi,
I am having rather silly problem, I've just purchased VAG cable and I am not able to find where the VAG connector is located in Fabia 2005 Combi. Please help.
Best regards,
Next to the steering column is a can cooler. Pull that open, then pull it down again and you will see the socket.
You need to apply a fair bit of downwards pressure on the compartment cover when in the normal open position to get the cover to drop down fully.
