Hesitation on full throttle
Hello guys,
I'm having a very annoying problem with my 1.8 (Normally aspirated) Octavia:
When I push hard on the throttle, the car doesn't accelerate well. As I lift up my foot a little, it goes much better.
Info:
I changed my MAF sensor recently so it's definitely not the cause.
The small black sensor right after the MAF on the intake pipe is disconnected (IAT I assume).
But AFAIK, if the sensor is disconnected then the ECU uses lookup tables which should drive the car fine.
Any idea of the possible causes ?
No idea, anyone ?
throttle body could be miss aligned or need cleaning.
Coil packs might need changing.
mluton: Makes sense, will try that. Thanks mate.
Could also be bad plugs.
