Constant limp home mode.
Pulled out of my driveway this morning. Changed to second heard a bit of a air leak and car went into limp home mode.
Opened the bonnet to find the pipe that goes from the top of the N75 down the back of the engine had sheared off. No boost on gauge. Replaced the pipe with some left over samco hose and the car is boosting but only to 5psi
Tried switching the engine off and restarting but still stays in limp home mode. Does it need the fault code deleting :confused:
you could try disconnecting the battery for 10mins have heard that this resets the ecu?
If theres anyone near you with a vagcom, I'm sure they would help you out.
