Removing aerial
Does any1 know how to remove the aerial from the roof? cheers
To remove the aerial from the base?
Unscrew it so it's loose and drops flat, then give it a sharp tug to remove.
It has an anti-theft T-shaped section at the end and it takes quite a hard tug to remove!!
I had to grip it with pliers.
If you mean the base as well you need to remove the headlining inside and there will be screws :D
Make sure you hold the base when you tug it cause i nearly pulled mine off lol as my tug was prob bit too hard lol
to remove the base..
open the boot
pull off the rubber seal from around the sides and the top
pull off the plastic trim that sits under the seal and covers the headcloth, this will take some persuasion but pull it downwards fast and hard.
you should be able to pull the headcloth down slightly at the back allowing you to see the nut on the base.
use a 22mm spanner (i think) unscrew the nut completely.
you should see the wire from the ariel going into a bit thats wrapped in spong, if you pull it out of there you should be able to disconnect it and the simply pull the ariel and base up out of the roof.
but if its just the ariel part and not the base just unscrew it and tug it out.
