Dynographs anyone?
I just got my Revo
The question is, how does it drive compared to "standard" ? :)
As Geof says, How do it compare to standard,
Also you say thats wheel power. Do you know what it is at the flywheel?
Looking at a few Jabba dyno plots, wheel power is usually 25hp or so less than engine power for the Octavia vRS.
hi
sounds like a very long time for a run!!! 1 min????
most 20vt engines will heat soak after 30 sec
depending on cooling,was there a power difference between runs?
really need to keep inlet temps below 25 at start and lower than 35-40 at end
any more and the car will pull timing and dump fuel to cool,you could really do with a inlet temp for the runs.
hope this helps
I was also suprized about the lenght of runs. I was out of town while my car was on dyno. Anyway it seemed that exhaust after cat is very restrictive. Im planning to get a full custom exhaust with freeflowcat to get better result.
Is 4 Bar FPR worth to have? i mean after the pipejob...
EDIT: Next time i will also use vag-com to get information on runs.
